Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: I need some nuts
  1. #21
    Dec 2016
    Helsinki, Finland, Europe
    Quote Originally Posted by MrWhoopee View Post
    I have had to make some similarly fine threaded nuts recently. I grabbed a broken tap and ground away all except the first good tooth. It made a great threading tool. Perfect form and much easier than trying to make one from scratch.
    This is what I have also used. Small internal boring bars for holes like under 1/4" are not so well suited for toolbit+setscrew but 1/2" 32tpi thread is already workable size in my books.
  2. #22
    Oct 2012
    San Antonio TX, USA
    Quote Originally Posted by Dave C View Post
    In box is full
    oops, sorry. Checked the ones I have and the only 32tpi one I have is 15/32. Threads ok onto a 15/32-32 Judco switch, has a minor ID of 0.454", so doesn't look like it'll work for you.
  3. #23
    Apr 2017
    Kelowna BC
    Maybe you can cast a nut for it from some quick set plastic ?
  4. #24
    Oct 2013
    USA MD 21030
    I found the data sheet for the T11-4 breaker, and it is 1/2"-32:
    https://www.alliedelec.com/m/d/a9d21...27f67b9dbf.pdf
    Airpax is now Sensata.
  5. #25
    Jan 2003
    On the Oil Coast,USA
    I hadn't thought of going that route, and may give it a try. My problem was not with single pointing the thread, it was the pita of having to make a tool to cut the thread inside that small hole.
    Do like I have done in the past and use a 10-32 tap for a threading tool.
  6. #26
    Mar 2015
    Central Ms
    Digikey has ordered the parts and they should be here in another week. Had to pony up another $2.76, but they waived the shipping fee. Good thing I have a lot of other work to do to the mill before I'll need the power feed.
    Lewis Grizzard
  7. #27
    3 Phase Lightbulb Guest
    Dang-it, wrong kind of nuts....
  8. #28
    Apr 2017
    Kelowna BC
    You are what you eat... you walked right into that.l
  9. #29
    Mar 2015
    Central Ms
    Even though the nuts are supposed to be here in a few days, I couldn't resist tying to make one myself, just to see if I still had the knack in me. I used a 1" hole saw to cut these out of a piece of 1/4" thick aluminum angle I found in the scrap pile. No idea what the alloy is.
    Looked in dad's Machinery's handbook that's a year younger than me, and found the thread depth of a 32 tpi thread to be .0203". The thread OD is .490, Chucked one disk in the lathe and drilled 29/64 hole, and used a tool that I forgot I had, and found while looking for something to cut the thread with. It's from a mini set that I bought years ago. Those are 1/4" shanks.
    The thread turned out kinda rough, but cleaned it up with a dental pick.
    I knurled it just for grins, but it didn't turn out the best. I think the stock is some crappy, gummy alloy.
    Too big to fit where it goes, so made it square with the minin mill. The corners need to come off too.
    It's not pretty, but at least it will do to hold the breaker in place while The servo is wired up and reassembled.
    Lewis Grizzard
  10. #30
    Apr 2017
    Kelowna BC
    Yup crappy gummy aluminum.
    Get some 1 inch or 3/4 6061 bar stock....handy to have around.
    K
    Turn od, then knurl, then thread and part off
