Results 1 to 10 of 21
Thread: First time to make a spur gear
    Nov 2010
    Portland Oregon
    Default First time to make a spur gear
    Hello Group,
    I want to make 2 spur gears for a DIY Bead Roller. I know I can buy them, but what's the point if I can make them and learn somethings along the way. What type of cutter is the question. Is a set the way to go? I was thinking of a single cutter but the specifics I'm not sure about?
    https://www.amazon.com/EVNSIX-Involu...ll-spons&psc=1
    Background info below.
    I am building a larger machine for making replacement floor panels in a car. I have a PEXTO 622 bead roller that I want to use the dies from. The gears on the PEXTO tool are 20 teeth, 2-3/16" OD and have a 15/16" bore. In researching it seems like they are 14.5 Pitch?, and are a 8DP? if I guessed it correctly.
    I have a BP clone, dividing head, and a SB 9" toolroom lathe as equipment for this project. I need a arbor for the mill which I think I can make. The other thing is any youtubes to learn from or a good old book to read. This is a one off for the bead roller, as I don't think I will be mass producing any gears in the future.
    As always look forward to any and all comments.
    TX
    Mr fixit for the family
    Chris
    Deep in the Heart of Texas!
    If you're going to duplicate the gears on the Pexto, that set you linked to ain't going to do it. It's 16DP. That makes some pretty small teeth--The same as the Craftsman lathe gears. That size will most likely crumble under the stresses of bead rolling. If you're going to make 8DP gears, you'll need an 8DP gear cutter.
    I think you can buy two gears cheaper than you can make two gears. Even if you just buy one cutter and the arbor. If you don't plan on making gears in the future, investing in the cutter(s) is silly.
    I just did a quick calc on your 8DP 20 tooth gear and I get 2.75" OD.
    You won't be able to cut gears unless you know what you have/want.
    Added:
    A 20 tooth 10DP gear is 2.2" in diameter, if that helps.
    Mar 2008
    Kent, U.K.
    Works out very close to 10DP. If you're going to cut them on your mill you'll need a no6 cutter.
    Monarch 10EE 1942
    May 2015
    Somerset UK
    The calculator I use makes it 10.058 DP. You will have to re evaluate your calculations before proceeding.
    Apr 2017
    Kelowna BC
    If you want to make them cheap, hand grind a single point tool to mount in a 1 inch bad into a collet.
    .it's a bead roller low speed gears not like trying to build high speed silent running gears.
    Good Luck, you will fell great after you pul this off.
    Jan 2013
    Michigan
    So much for a spur of the momentt project.
    Saskatoon, Saskatchewan
    Quote Originally Posted by Peter. View Post
    Did you know gear cutters made in China are numbered the opposite of US made cutters?
    A bit of information from that (gasp!) other site.
    https://www.practicalmachinist.com/v...sation-307723/
    Looks to me China follows the rest of the world. US gear cutters are bass-ackwards.
    Mar 2002
    Kirkland, Washington
    Chris
    It is close to a 10dp gear. I would grind some HSS steel lathe bit to close to correct shape/size as possible and run it like a fly cutter. As has been said the device it is a slow speed operation and not overly precise.
    Why not add cutter grinding and gear cutting to your bag of tricks. The Students Shop Reference Handbook as well as Machinery's Handbook have full size tooth profiles for gears.
    Go for it and let us know questions and progress.
    Pete
