Results 1 to 9 of 9
Thread: trailer axle U-bolts - what steel?
    Kirkland, Washington
    Default trailer axle U-bolts - what steel?
    I'm building a trailer. It's looking like I may need to make my own U-bolts. Are these special steel? It's pretty important that they not fail.
    Do you know what kind of steel I should use?
    I'm stumped.
    metalmagpie
    Aug 2007
    Custer WA
    There are places around that make u-bolts cheap. Probably not worth doing yourself.
    Some info.....
    http://gittspring.com/measuring-support/
    Aug 2018
    Loveland,CO
    Northerntool, $25 for set of 4, with two mounting plates, for 3" , 6'000 # axle, plus other sizes.
    Jul 2017
    Buffalo NY USA
    Much of the higher-grade automotive stuff is just a medium carbon such as 1045, although later models (last 20 years) have some bits of 4140
    On the Oil Coast,USA
    Dozens of places online-
    https://www.dsuban.com/custom-u-bolts/
    They are usually medium carbon steel like mentioned already,but also feature rolled threads which will be 20-25% stronger than cut threads.
    Yes, I can order custom u-bolts. But I don't see why I should.
    I think I'll just make some with 1045 rod.
    metalmagpie
    Stevens Point, WI
    Recently I built a trailer and needed U-bolts of an odd size. Found a local place like mentioned that made them on the spot for $7 each with nuts and washers.
    Jan 2014
    In the desert
    Last ones I made I used 4140 because I had it on hand.
    Most towns have a place that specializes in commercial truck suspensions and springs. They can custom make them for you.
