Results 1 to 10 of 40
Thread: searching for a viscous dampening fluid
    Default searching for a viscous dampening fluid
    so thick it's like molasses on about a 40 F day, yet perhaps unaffected by temperature extremes...
    and it has to be able to stick and bond to anything it touches... let me know - i'll check this out in the monyatta and thanks
    Feb 2006
    Phoenix
    Honey might be what does the trick.
    Allan Ostling
    Jan 2014
    In the desert
    Honey will get thick and even crystalize out sugar at low temps.
    Chilliwack, B.C.
    I recall seeing different weights of silicone fluid at a hobby supplier. Maybe something thick enough there-
    Oct 2005
    British Columbia
    I believe Toyota still stocks their viscous fan clutch fluid in 3 grades 3,000 CST, 6,000 CST, and 10,000 CST.
    Give 'em a call to see if they have it, that is if those viscosities are suitable. You did not state viscosity or application.
    I think Nissan is another source, I'm sure there are others.
    Feb 2006
    Phoenix
    I keep my raw manuka honey in the fridge. It is thick, but doesn't crystallize at 40F. It is the best honey to eat, but probably too expensive to use as a damping fluid.
    Allan Ostling
    Jul 2017
    Buffalo NY USA
    I balanced the driveshaft in my jeep by pouring a quart of 90-wt oil into it and welding the hole shut. Worked like a charm, smoothed that thing right out at highway speeds. (home-made driveshaft for a custom app)
    May 2005
    Australia (Nth. Brisbane)
    They do here in Australia. Hobby shops are another source with posibly more choices.
    Nev.
    Sep 2009
    NW Illinois USA
    I like this
    Oct 2009
    Ontario, Canada
    Non-Newtonian fluid of some sort?
