Results 1 to 10 of 10
Thread: Air Cooled
    Jan 2014
    In the desert
    Default Air Cooled
    For those of us not yet willing to spring for a water cooled torch...
    How much weld can you typically lay down before the torch becomes to hot?
    Is it just that the torch become to hot to handle comfortably with your TIG gloves on?
    If you are not reaching the duty cycle of your welder is it going to damage the torch if you just keep going by switching over to a heavier welding glove?
    When you reach the point where its too hot how long do you usually have to wait for it to cool down?
    I know "it depends" is part of the equation. Environment and current are probably the biggest "secondary" factors.
    Jul 2015
    S.E. MI, Metro Detroit
    Air cooled torches are available from 80 amp to 200 amp, the 200 amp torches are quite expensive.
    I notice your location is 'in the desert', I used a water filter, and used my water cooled torches
    with city water. Worked fine for years, if freezing is not an issue.
    Larry
    Nov 2008
    SF East Bay.
    How much weld can you typically lay down before the torch becomes to hot? IT DEPENDS ON THE AMPS
    Is it just that the torch become to hot to handle comfortably with your TIG gloves on? NO, MANY PARTS ARE THERMOPLASTIC AND WILL MELT
    When you reach the point where its too hot how long do you usually have to wait for it to cool down? YES
    The torch has a duty cycle just like the welder has. If your WP17 torch is used over it's rating (150 amps??) for any length of time you will find it softening and maybe melting and possibly burning. A guy on welding web used an AHP 200 with helium and the stock torch (WP17) to weld thick aluminum at full power for an extended time. The AHP did OK, the torch melted.
    Dan
    Helsinki, Finland, Europe
    WP-26 that is the largest common air cooled torch is good for one 1 feet bead on aluminium at 200 Amps.
    Uncomfortably hot after that and soon after it starts to smell like toasted rubber.
    Welding aluminium (AC) puts lot more heat on the torch and it doesn't take large part that you need to crank the current already to 200 amps.
    Water cooled torch has been one of my best investments.
    WP-26 was really bulky and cumbersome to handle compared to WP-20 water cooled torch that has even better capacity.
    Sep 2018
    The cable can melt out of the gas hose. Might have done that years ago :-(
    Liquid cooled is GREAT!
    I run glycol. My first was a home built cooler, but when I traded up it came with a cooler that just needed minor repairs.
    Sep 2011
    Langley, British Columbia
    Quote Originally Posted by metalfixer View Post
    ...I used a water filter, and used my water cooled torches
    with city water. Worked fine for years, if freezing is not an issue...
    Yup, lots of guys start out that way--some never use a cooler. The advantage of city water is that
    you have clean, cold tap water flowing through the torch--no recirculation. Torch getting a little hot?
    Open the valve a bit more and feed more water through...
    Keith
    __________________________
    Have a cooler on a 210 everlast; one of the best things I have done. The only worry I have is making sure the cooler switch is on.
    Sep 2011
    Quote Originally Posted by Tungsten dipper View Post
    ...The only worry I have is making sure the cooler switch is on...
    Your cooler should be wired to come on automatically when you turn on the welder. You will forget one day...
    Keith
    Mar 2015
    My skin usually gets really sun burned before my torch gets too hot to handle, so not an issue
    It is wired that way, the cooler still has a on/off switch which is taped in the "on" position, so I don't forget.
