Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 106
Thread: Computer Issue Boot Disc OT
    Sep 2006
    Big Prairie Mi.
    I did,
    Came up with so many that I don't know where to start. That's why I thought I would start here.
    I did find a WIN 7 recovery disc from an older computer but I don't want to re-install, just repair to get up and running.
    Also found this ....... $20 for the diagnostic and repair disc.
    JL.................
    Most windows versions are available for download from the microsoft site. Just need a valid product key. Home and pro both use the same ISO, your product key is what determines what version is installed.
    Also, on any w7 disk you have a menu choice to install, upgrade or repair an installation, should appear on the first menu that shows up.
    https://www.microsoft.com/en-us/soft...nload/windows7
    Edit: ensure you get the right 32 or 64 bit version.
    Edit 2: sometimes can download the ISO with a product key if you are in the insiders group.
    Edit 3: At least it's w7, with ten every update changes the version number, so even the original install disk will return a 'wrong version' error in many cases
    Try "Plop" boot disk, it's free. I used it quite often.
    I can't get past the black screen no matter what I do. I put the Win 7 recovery disk in and it doesn't see it.
    JL....
    Jan 2013
    Michigan
    IMHO, one approach and solution: find a tutorial on how to backup this system using a linux recovery distribution image.
    The first step of that will be using a different computer to download a linux recovery distribution and burn it to a thumb drive. You boot that on your problem computer and then follow the instructions to image the computer to an external hard drive, like a cheap USB drive. That cheap USB drive will be very useful in future backups.
    In the future you may want to find a way to do your internet activities on a more secure OS, which could be linux. For XP security and reliability you can run XP in a virtual machine and not allow it to access the internet.
    If your current computer is old and slow consider finding a cheap used computer (spending money to upgrade old computers is rarely cost effective). If you hunt around you may find a $30 computer with monitor that is a huge upgrade - at an estate sale or auction.
    JL....
    Again: do you know the boot sequence is OK?
    The BIOS setup should work if the computer itself is OK
    Jun 2012
    San Diego, Ca *** Please let us know where you are from too.
    As others have said .. boot with a linux disc which will allow you to look at the files on the
    HD and see if they look healthy.
    John Titor, when are you.
  7. #17
    Sep 2006
    Big Prairie Mi.
    JL....
    If you don't want to alter the bios boot order, you can restart then hold the f12 key, it will show show a boot order menu, select the cd drive and it should boot to the CDrom.
  8. #18
    No, because I can't get past the screen I posted a picture of.
    Also tried all the F keys. Still can't get past the black screen.
    JL......
  9. #19
    Sep 2006
    Big Prairie Mi.
    You can't get past that screen even after a complete shut down?
  10. #20
    Jan 2008
    The keys need to be pressed before you get to the screen you posted... If the screen shows up - you are too late.
    sam
