Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: Dumb machining questions. The jig that an engine gets bolted to for machining called?
    Stevens Point, WI
    Default Dumb machining questions. The jig that an engine gets bolted to for machining called?
    The round bar that a guy would bolt an engine too using the mains which then sits between two centers, whats that called? Is it a make it yourself kind of deal? I have a small engine I need to bore the cylinders on and need to get at it soon.
    Like in the pic but without the power unit.
    Jan 2002
    Huntsville Ala
    Well, in general, contraptions or devices whose purpose is to hold work pieces in the proper place and alignment for machining are called fixtures, as I understand the term.
    In the world of engine building/machining there may be some more specialized term, but if so I know it not. If I were going to coin such a term, I'd probably call it a "dummy crank."
    yup, you want to call it fixture to find it searching. jigs are for drilling.
    RMC, who's photo you show calls it "4th Axis Rotary Table and Block True Blueprinting Fixture"
    I don't know that you are going to get anything more exact than "engine block fixture". page 2 here
    https://rmcengine.com/wp-content/upl...18-Webpage.pdf
    PS....I'd guess the engine is bolted to the t slotted face place rather than sitting between centres. I wouldn't think it would be rigid enough just attached to a bar between centres, no first hand knowledge, but that would seem too light a set up
    Stevens Point, WI
    I found this old gem. Post # 796
    there you go....looks like it would work after all.
    Buffalo NY
    DZER
    Sep 2009
    NW Illinois USA
    I would call it a mandrel.
    Dec 2008
    Kendal, On
    I'd call it a crank locating, cylinder boring fixture.
    A simplistic definition, fixtures hold the work, jigs are held TO the work. It can get more complicated and blurry than that, but that's pretty much the jist of it.
    Apr 2017
    Kelowna BC
    Jigs guide cutting tools.
    Fixtures hold the workpiece.
    Nov 2004
    Check out Goodison Supply, they carry a full line of engine machining/rebuilding supplies/tools...I believe BJH make a block truing jig for a Bridgeport style mill to do most of the block machining,( lifter bores, deck, boring) not cheap .. http://bhjproducts.com/bhj_content/p.../bt1_intro.php Good luck!
