Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Large End Mill for Bridgeport
  1. #41
    Apr 2017
    Kelowna BC
    Mystery metal it's not always saving money.. as far as machining goes.
  2. #42
    Jun 2016
    Quote Originally Posted by MrWhoopee View Post
    Here's a simplified cutting speed chart
    Is "Ally" aluminum in your table? Assuming it is, 1000-1500 SFM for an HSS tool is a bit ambitious.
  3. #43
    Aug 2004
    Sunny So Cal
    For me? A nice lil surfacer would be nice. Even a 1/4" HSS bit, not being pushed too hard.
    Oh yeah, scale that blank. JR
    Errr. I do have some insert mills. Not the point.
  4. #44
    Sep 2011
    Langley, British Columbia
    ...I never put much thought into sfpm or cut speeds, I just kind of know what sounds and feels right...
    That's pretty much how I approach it. I tend to run my endmills at slower RPMs but with greater DOC and feed
    rates than what the numbers say you should be using. A lot of the charts I have seen are designed to work on
    larger, heavier machines. As soon as you start working with lighter machines any give or flex you introduce will
    have a negative impact on your tooling. Running at slower speeds but with higher rates of cut can actually
    remove more material per minute than what you can achieve by running them faster and at the same time you
    get much better tool life.
    In any case whenever I'm using HSS endmills I always use roughing mills if at all possible. Marching a 3/4" endmill
    through a piece of steel with a full width cut and a depth of 1" is always a very satisfying thing to watch...
    ...What is "cut speed"?
    I think it refers to surface feet per minute...
    Keith
    __________________________
  5. #45
    Deep in the Heart of Texas!
    Same here. And they'll talk to you or give a touch response through the crank. You can fell when the bit wants more or says ease-up a little.
  6. #46
    Sep 2011
    Works with power feed too. Once you've used a machine for a while it will tell you if it's happy with the
    combination you're using...
    Keith
