Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Ot- semi w 40k lbs of bees
  1. #21
    Dec 2016
    Helsinki, Finland, Europe
  2. #22
    Jul 2016
    Brampton, Ontario
    Is that a Xenomorph lair?
    Sent from my SM-G930W8 using Tapatalk
  3. #23
    Jan 2003
    Chilliwack, B.C.
    I've long wondered why airplanes can't weigh themselves. They sit on suspensions, which compress as weight is added- you should be able to get a pretty good idea of how heavy a plane has become (or how light) by measuring and averaging readings from 'extensiometers' mounted on each strut. The crew would be able to see the result as the plane is being loaded, and then gross errors could be seen. Fuel load and passenger load would be monitored readily, and if something disagreed you could check it out before leaving the ground.
    I've never heard a pilot or any crew member saying anything about a self-check of loading conditions- nobody comparing an on-board weight indicator with a check sheet- as far as I know they don't exist.
  4. #24
    Feb 2016
    Edmonton, Alberta, Canada
    Probably because then the suspension components would have to be calibrated, so they could provide a meaningful value, and then periodically re-calibrated (as the suspension is used, it likely droops a little over time, or parts are replaced). Anything else would be a safety hazard, as if it were just a overall estimate, as a double-check value, air crews may wind up using it instead of actually weighing the plane, and possibly flying with an overloaded plane.
