Page 1 of 2 12 LastLast
Results 1 to 10 of 32
Thread: Puller for plastic wall anchors
Hybrid View
    Jan 2010
    Germany
    Default Puller for plastic wall anchors
    We all live in homes. We all mount things to our walls. We all use plastic wall anchors sometimes. We all need to remove these anchors sometimes and fill the holes. It has been my experience trying to pull them out of the wall is not always so easy. Grabbing them with needle nose pliers most times ends up with a piece breaking off and most of the anchor is still in the wall. Threading a screw in partially and pulling with pliers is less than perfect.
    But now ladies and gentlemen we have the perfect solution. May I introduce you to my wine cork puller converted to a plastic anchor puller!!!! I cut off the corkscrew and welded a normal screw to the remaining shaft. Now we have a plastic anchor puller.
    Jul 2006
    Dracut, Massachusetts
    Clever and nicely done! You know, years back when I managed and maintained a bunch of rental units this would have been a genuinely useful gadget to have.
    That's what I like about visiting this forum.
    We are making the world a better place by eliminating one petty annoyance at a time.
    There is hope for mankind after all!!
    Jan 2010
    Germany
    Quote Originally Posted by alanganes View Post
    I will try to get someone to take a video of it in use. It really works great. We have a large home and lots of pictures and fixtures so it will be really handy I think.
    Jan 2002
    Huntsville Ala
    You can sometimes just cut off the flange and push it on into the wall.
    May 2006
    Quote Originally Posted by lynnl View Post
    Bingo, they are meant to go in one way and resist the other esp. when a screw is inserted, once the flange is removed they will just continue their journey into the dead space and drop to the floor with no further damage to the wall...
    Jan 2003
    Atascosa County, Texas
    That's what I always do/did. In the first old house in Ohio, it had plaster over slat walls. The PO used those plug anchors for everything. And if you looked down a wall, you could see some that were painted over. I just used a single edge razor (in a holder) and cut the flange off and pushed them through the wall. Most of the holes would cover with a little spackling. The aluminum ones were a little more work. I drilled the flange off and a little below the surface then plastered over them.
    Dec 2008
    Kendal, On
    Nice solution. Those kind I've always just done as above and pushed them through. When we bought our place the previous owners used the screw in type. Everywhere. I have a lifetime supply of those suckers even after giving a bunch away, and haven't used a push in one since.
  8. #8
    Mar 2015
    Wall anchors I use have a Philips head built into the face.
  9. #9
    Nov 2007
    Woodinville, WA
    That's what I use unless I need to grab a steel stud with a toggle for strength. They come in both plastic and "metal" (some form of zinc cast). Even though they are self drilling I almost always drill a small pilot hole - less issues in unknown plaster, and you know if you hit something you didn't expect. Like these : https://www.zoro.com/primeline-zip-i...waAqq1EALw_wcB
  10. #10
    Dec 2008
    Kendal, On
    Those are the ones that were all over my walls when we bought the place. Both plastic and metal. They work great too.
