Results 1 to 10 of 14
Thread: Storage cases for single end mills and drill bits?
    Mar 2019
    DFW, TX
    Default Storage cases for single end mills and drill bits?
    I'm looking for a source for small plastic cases for single end mills and drill bits
    Something like the hinged plastic cases that some end mills ship in, I just can't seem the cases for purchase
    I haven't seen too many drill bits that come in containers or tubes other than carbide bits.
    Can't think of the website... Thomas.net ??? Alibaba ?? You might be able to find a supplier there, or call some of the end mill manufacturing companies and see if you can get a lead there.
    JL...
    Jul 2017
    Try a sporting goods store that sells ammunition reloading supplies. I use rifle ammunition boxes to store some of my endmills. It keeps them separated and organized. There are a few different styles available.
    I put mine in PVC tubing I cut the tubing to length on my mitre saw smack one end with a soft hammer and it will not come off. Push the other end on by hand and it will come off when you twist it a little also mark it so you know which end to twist. The tubing is cheap enough the end caps are around .30 cents at Lowes or Home Depot.
    frankie
    I also use PVC. But I see no reason for the hammer bit. I glue an end cap on one end and the other is a friction fit. You can write the size and other information on the end caps - just find ones that are flat, not with other stuff already cast into it. Or sand them flat with the belt sander. The end cap with the writing on it is the one that comes off.
    Jul 2006
    Dracut, Massachusetts
    Quote Originally Posted by Lowe.Buuck View Post
    Now why didn't I ever think of that? Those would work great without the covers as drawer organizers to keep small end mills, tool bits, and such from rolling all around the toolbox drawer. The 50 round ones made for handgun ammo would be good for some of the shorter tools as well. Thanks, great idea!
    Aug 2018
    New Jersey, USA
    They are also good to store AA and AAA batteries.
    Sep 2009
    Madison Wisconsin
    McMaster offers storage tubes for individual mills and drills. They run from about $1.00 to $3.00 each.
    https://www.mcmaster.com/storage-tubes
    As mentioned very few manufacturers use tubes for drills except for the larger sizes. Anything under 3/4" generally come in an envelope.
    Atascosa County, Texas
    Did anyone read post #1?
    I've been getting all my recent spiral flute taps in the hinged cases. Also the carbide spotting drills. But there's no markings on the cases that I recall other than make and size labels. I'll have a closer look and see. IIRC, they are the YG-1 F4 series taps from Amazon. Nice sharp taps, by the way. I've had no problems power tapping with them.
    Apr 2017
    Kelowna BC
    Not sure where you keep them, but I drill holes in thick white plastic to hold my big ones.
    If you are near a neon shop try to get some electrode boxes the have 1/2 or 5/8 squares about 50 plus per box, they are cardboard but hold up for years.
    Boxes hold a hundred, they are around 8 inches square.
