Page 21 of 28 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 273
Thread: Vertical hit and miss engine
  1. #201
    Mar 2008
    Barrie, Ontario, Canada
    Aostling and others wanted to see how this engine reacted under load/no load conditions. I don't have any machinery designed to have a varying load, but I did want to show him and others how a varying load affects these model hit and miss engines. So--Turn up your speakers, click the video link, and set back and listen.---Brian
    https://www.youtube.com/watch?v=JRtmoje5uJA
    Mar 2008
    I just listened to my video, and noticed that I spoke in error. The engine under load hits every other stroke, same as any four cycle engine, not on every stroke.
    Feb 2006
    Phoenix
    After attending my 60th high school reunion in Seattle yesterday, I am now in Anacortes. I just played the video, a fitting end to a nice day. Thanks, Brian!
    Allan Ostling
  4. #204
    Mar 2015
    That little engine sounds just like a Cat RD6 dozer lugging about when under load.
  5. #205
    Mar 2008
    I am now in that "post building slump" that always follows a successful build. The engine worked great, started and ran almost the first time I tried it, and ran well. I did manage a video showing the engine running under load conditions while lifting a weight. Rather crude, but it did the job. I have had numerous ideas for making a machine to drive that has a variable load, but that is not as easy as you would think. It would have to cycle in and out of the "load" side automatically, but can not transfer any load back into the engine when being ran in the "no load" situation. --In other news, I got stung by a damned bee yesterday. I was mowing my lawn with my garden tractor, when I felt a small "jab" in my right hand. I looked down at my hand and seen a big yellow and black bee, and immediately gave my hand a shake to knock it off. The bee drilled me, and damn, did it ever hurt. I haven't been stung by a bee since before my dad died, so it had to be over thirty years ago. I'm not allergic to bee stings so finished cutting the grass and came in the house and held an ice cube against the sting for an hour until it finally quit hurting.
    Apr 2009
    Hi Brian, a disk and wheel friction drive could vary speed and hence the load and if you had a hole in the centre of the disk that would give you a 'no load' position. A fan could be the load.
    A hysteresis disk could be another way to go.
    John
  7. #207
    Jul 2007
    Brian, why not go back to your roots and build a buzz saw, complete with rocker table? THAT would be a variable load!
    Duffy, Gatineau, Quebec
  8. #208
    Mar 2008
    Too late Duffy--I already have a model buzz saw from a couple of years ago. I did think of using that, but was hoping to come up with something a bit more finger friendly. John--That has given me food for thought. These little engines are so powerful that a fan doesn't load them enough to make a difference in the hit and miss cycles.--Brian
    http://bbs.homeshopmachinist.net/thr...highlight=buzz
    https://www.youtube.com/watch?v=DKiX...ature=youtu.be
    Mar 2015
    An inline 3 cylinder IC engine?
  10. #210
    Dec 2008
    Kendal, On
    What about an electric generator? would be pretty easy to play around with varying loads (lights?) via relays and such, or even a geared down slow turning cam wheel triggering switches (for visual mechanical effect)
