Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Air Hose PIPING in the SHOP using galvanized EMT from FINLAND must see.....
    Buffalo NY
    Default Air Hose PIPING in the SHOP using galvanized EMT from FINLAND must see.....
    Americans need to expand their mind,
    and get hip to this stuff. Really.
    --Doozer
    DZER
    On the Oil Coast,USA
    Everyone,Americans included just need to stop using thread tape and use proper thread sealant instead.No leaks,ever,period.
    https://www.permatex.com/products/th...hread-sealant/
    Aug 2004
    Sunny So Cal
    Well. I thought all Engine Builders and Plumbers knew this by now.
    I thought I did. The Teflon tape with some kinda blue strips in it are top shelf, bees knees, the sh*t. Blue.
    It is good tape. I wouldn't use it on n engine. JR
    Mar 2015
    Why not use thin wall PVC tubing with brad nails taped around the outside of the tubing?
    Sent from my iPad using Tapatalk Pro
    Helsinki, Finland, Europe
    Not really EMT but thin wall water pipe with crimp fittings. Commonly available in galvanized, copper and stainless.
    All new installations are either press fit steel/cu/SS or PEX.
    Downside is that crimp fitting tool is crazy expensive, not sure if there is any low cost options under 1 grand today.
    Mar 2018
    Finland
    I have a ****load of PEX tubing left over from building my house, thought of using it to run air lines. Though I probably should buy a better compressor first.
    Mar 2015
    Quote Originally Posted by DennisCA View Post
    I have a pex crimper, would be nice to use it again!
    I have to wonder if this would be a code violation in some places where conduit being used for air could be mistaken for conduit being used for electrical?
    Iron or copper works well for me. What's easier than sweating copper?
    My other thought is, how long before the welded seam starts to pin hole from moisture?
    JL................
    Another home shop project that I have seen here in FINLAND
    Aignep Infinity makes it pretty easy installation, even the T-connectors incorporate internal "swan neck" to keep the water out of downlines.
    https://www.aignep.com/eng/Pipe-fitt...NFINITY-Series
    Not cheapest option but pretty straightforward to install.
    JL................
    Like I said its not EMT conduit.
    Water pipe, crimp fittings, AFAIK rated for at least 16 bar and 110 cel temp. Dunno if it is officially rated for pressurized air, copper and SS are probably preferred if you ask the manufacturers.
    I'd probably use something not prone to rust but..
    And in here EMT is always aluminium or PVC pipe.
    And nobody does or knows how to "sweat" copper piping, old installations are high temp brazed but never sweated with tin based solder as "sweated" solder joints are not permitted in code.
