Results 1 to 10 of 21
Thread: Collet closer tube length
    Mar 2015
    Default Collet closer tube length
    A huge thank you to Sparky for sending me his old collet closer. I have to cut the length of the tube down to match my headstock. The question I have is about thread engagement. Do I cut the tube so the collet is engaged by at least three threads in the loose state, or most of the threads are engaged in the tightened state? What is the common practice for this?
    Jun 2007
    Anderson SC
    Glad you have to shorten the tube, stretching it is much harder.
    "three threads in the loose state" I don't understand this I guess, you need to be able to totally unscrew the collet to be able to remove it. To just remove a part, from the tight position only takes 2-3 turns.
    "most thread engaged in the tightened state" well, that is how I did it but very scientifically. I examined a bunch of collets that I had and found that they seemed to have been engaged by about half their threads in their previous lives as evidenced by the wear/polish on their threads.
    Of extreme importance is that the bar does not run out of threads on the collet before the part is tight !! There is some variance there depending on the part in the collet and if its undersize at all. Leaving a minimum of 3-4 turns remaining at tight position as a minimum would seem like a good guess.
    Does the spindle nose adapter fit ok? That is protrude enough from your spindle? (thats the area that had me a bit worried, even though its MT5 like mine was)
    How about the tapered end piece with the thrust bearing, fit ok?
    A pro-tip on length is NOT to shorten it, but instead to make a collar to take up the space.
    Once you get that right, and have tried it for a while so you know all is good, then you can, if you want, shorten the tube by the amount of space the collar takes up. jusy be sure you account for any thrust washers or bearings.
    Mar 2015
    Both seem to fit perfectly. The nose piece sticks out far enough and the rear piece fits perfectly even with the back cover on.
    Think I will try that first. I only have one 5c collet at the moment, it's the one Sparky sent.
    Feb 2005
    gettysburg pa.
    post 3 has it right make up a slip on spacer. that way you can modify the spacer to get it right. I used a collect setup made for a southbend 9 in my 12 inch atlas it took a 1 1/2 inch spacer. now that I have a southbendd 9 I just slide the spacer off..
    Mar 2015
    Quote Originally Posted by bob308 View Post
    This tube is a good 6 to 8 inches longer than needed. I can cut it down so it only has a couple of extra inches to play with.
    Jun 2007
    Anderson SC
    Sounds like a good plan. Making up a spacer is a good idea too. Don't know if you are going to use that POS wheel for now but a spacer will leave enough meat to change out that wheel in the future also.
    Glad to hear things are fitting up nicely ! I am never that lucky with my projects.
    Aug 2004
    Sunny So Cal
    Yup, Jerry nailed that one, for once Kidding. Great idea an I have one here that is exactly that. Great advice J.... JR
    Mar 2015
    A bigger wheel is in order, but also a hand wheel that mounts to the D1-4 spindle. My lathe doesn't have a foot brake. Could just mount the face plate..
    Jun 2007
    Anderson SC
    Why do you want a handwheel on the chuck side of the spindle? To loosen and tighten the collet I would just put the lathe in backgear which hold the spindle well against rotation.
    There are some pics of a Royal drawbar here https://www.ebay.com/itm/Royal-Produ...gAAOSwj4hcvgTx
    I had a Royal years ago and their wheel was very nice, it was rubber coated.
