Results 11 to 20 of 44
Thread: Spade drill holder
    May 2015
    Thanks to both of you. I appreciate it.
    Sent from my iPad using Tapatalk
    Jul 2006
    Dracut, Massachusetts
    Quote Originally Posted by jdedmon91 View Post
    Now I need to go digging through my stuff to see if I have that issue here someplace.
    Looking forward to see what you come up with!
    May 2015
    Quote Originally Posted by alanganes View Post
    Iíll look to see if I have that issue, it may be one I let a friend have. My plan is to use rage blade, the photo and work out the first holder. Even used holders on EBay is expensive.
    OREGON
    I’ll look to see if I have that issue, it may be one I let a friend have. My plan is to use rage blade, the photo and work out the first holder. Even used holders on EBay is expensive.
    I just looked at my copy, it is Jan/Feb 2015. The article shows a holder for 130 degree spades. I don't know if flat bottom spades work with the same holder or not.
    May 2015
    Somerset UK
    All of the big names such as Sandvik and Kennametal produce this type of drill system, but there is no standardisation you could rely on.
  6. #16
    May 2015
    Yes from what I seen there is several types. I googled spade drill holders an found this photo The spade drills I have are this style, so the plan is to try to machine custom holder up in the shop. Since the commercial ones Iíve priced are expensive itís worth a shot
  7. #17
    There is no reason why an HSM person can't make a spade drill holder like the one shown above. They are very simple, really.
  8. #18
    May 2015
    We shall see
  9. #19
    Spade drilling is awesome but takes a great deal of power and a stout machine. Drill straight through in one shot if possible, inserted spade drills do not enjoy making small holes larger.
    2 11/16" spade drill through 3 1/2" of 1018 steel in 4 minutes per part.
    This is a 24" Dia. chuck 30 horsepower spindle W&S turret lathe, do not try this at home (-:
    This machine will not stop, it will rip the tang off a 3" taper shank drill.
  10. #20
    Feb 2015
    NC
    Wow!
