Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Spade drill holder
  1. #41
    Apr 2017
    Kelowna BC
    You are going to make more without trying this one to see how it works ?
    My lathe has 7 hp, and I can bog it with my bigger drills..
  2. #42
    May 2015
    Iíve already tried the first drill. It was an 1 3/64 spade. It was the largest. It worked ok. Iíd be concerned if it was an 2 inch or larger.
  3. #43
    May 2015
    Default Spade drill holder
    Iím working on the rest of the spade drills the other 3 are 90% complete. Still need to mill the reliefs and blue them with cold blue. There was 6 spades given to me. The two smaller ones are duplicates, so I will only have 4 drills made up. To make it easier for me Iím stamping the spade size on the drill body so I can ID it quickly.
    The first drill was a 1 3/64 drill and I did test it on a piece of steel that had a 1/2 drill hole in it. The spade drill performed like it was supposed to. If I do any more it will be to give me some options up to 1 1/2 inches. My lathe wonít be able to handle much larger drills than that.
    Iím working on the video for my channel however I thought Iíd post an updated photo
  4. #44
    May 2015
    The finished product on its wall mount.
  5. #45
    Apr 2017
    Kelowna BC
    Maybe trim your brass hammer...
    I don't feel like retelling the story about the guy next door getting a piece lodged in his nutsack.. ..
  6. #46
    Feb 2005
    gettysburg pa.
    we always made our own. no big deal. justmake shore the bit is centered on the shaft.
  7. #47
    May 2015
    Actually the hammer isnít mushroomed. This hammer was a coated one that the coating fell off of. I made up a Delrin handle for it, and it hasnít been used that much. In fact I was stamping the sizes on the drill bodies
  8. #48
    May 2015
    Quote Originally Posted by bob308 View Post
    Yes the project wasnít that difficult, just not having a one to use as a guide was a challenge. I used a photo and machined one complete first. Then machining the last 3 as a group
  9. #49
    May 2015
    Iím releasing the videos on the machining process of the drills and improvements to the process as I went along. Parts 1 and 2 will be the first drill. Part 3 is finishing the rest of the set of 4. Here is part 1
    https://youtu.be/POXeivAV1rY
  10. #50
    Spade drills are the way to go if you have the power.
    3" spade through 6 1/8" of annealed 4140 hr, took about 45 minutes, it got a bit steamy however.
    Part with the lathe work finished, it took 9 1/2 hours of drilling and setup to remove 75% of the material in a 15" CNC lathe (not nearly a large enough machine), the finished major diameter is 10 3/8", the bore is 5.625" +- .005", also 2 retaining ring grooves on the OD, .125" wide by .187" deep. It now goes into a mill where eight equally spaced 1.531" holes are drilled between the retaining ring grooves, to make it more fun the holes are angled at 5 Degrees in the X axis.
