Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 91
Thread: How do you move a 10ee?
  1. #81
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by Peter. View Post
    Ah, you have the later modular drive if it's a 5hp I suppose. Must be nice to use.
    Its like butta And, it will run on single phase. I did make sure to get a bunch of back up tubes for that industrial rectifier too. JR
  2. #82
    Aug 2004
    Sunny So Cal
    Ok chaps, time to get serious, I am now an owner of a 10EE, $1625.
    Sweet! Yer gonna love it with whatever drive system you decide on. The bulk of the machine is one of the main reasons its so darn fun to use. JR
  3. #83
    Mar 2015
    Quote Originally Posted by JRouche View Post
    It's nice to remove the machine as a variable as to why a part isn't to spec
  4. #84
    Mar 2008
    Kent, U.K.
    Funny, that's my favourite saying - if it's wrong, it's not the machine's fault!
    Monarch 10EE 1942
  5. #85
    Dec 2004
    Toronto
    Another way to drive the DC motor if the AC-DC Section is compromised: http://www.beel.ca/
    Geoff
  6. #86
    Aug 2004
    Sunny So Cal
    Hahaa. Even with my most clapped out machine I am ALWAY the short coming. JR
  7. #87
    Mar 2015
    Quote Originally Posted by ammcoman2 View Post
    Geoff
    Thank you for the link
  8. #88
    Jan 2014
    Edmonton Alberta
    Teco builds VFD that don't have to be up sized to convert 1ph to 3ph 220-240 volt,the guy said a 5 hp VFD will run a 5 hp 1ph.With your 6 hp motor you would have to get 7-1/2 VFD,they jump from 5 to 7-1/2.The 7-1/2 hp was $1000 cdn and made in Italy.
  9. #89
    Aug 2006
    Beaverton, OR
    When I got mine I ran it off a 15hp RPC. That got old fast so I yanked out the motor-generator and replaced it with a 2kw brushless servo motor. Since then I have redone it with a 5kw brushless servo motor and I have so much power now I have never used backgear. I have a thread over on PM all about the conversion. Only issue I have ever had is I ripped the bellows coupling between the motor and gearbox in half, its really the wrong coupling for the job but it's what I have.
    The new 10ees out of the factory use either a 10 or 15hp motor with a VFD, its the only way to get the low end torque. Unfortunately you just cant throw a VFD on the machine as you need to power other stuff and you may get an unbalanced load.
    If you are lucky you will have the WIAD tube drive. These things run off of single phase and are pretty nice.
  10. #90
    Jun 2007
    Anderson SC
    Not familiar with the 10EE but what about just using a 5hp dc motor drive? They are often single phase input.
