Results 1 to 10 of 27
Thread: Disgusting socket unjointed fix
    Feb 2011
    Default Disgusting socket u joint fix
    I do a lot of repair work involving radiator hose clamps. It is always a problem reaching them and loosening and tightening . When you use a universal joint and a socket it is too bulky and it Falls apart and comes off. Also none of these supposed u joints are true cross u joints. So I found a solution. I found a true cross universal joint on a radio controlled truck axle. I machine it and Tig welder it to a long Phillips screwdriver and a short socket that fits the hose clamps. It works great .it does not fold up and is very compact. I will admit it is not as strong as store bought ones but not everyone is a clumsy ham fisted mechanic. It seems that most mechanisms are getting smaller and smaller and more compact but the tools are getting klutzier and larger so that they can say lifetime guarantee.Edwin Dirnbeck d d
    Feb 2011
    Tried to edit the title 3 times . unjointed to u joint. Edit doesn't work for me. Even tried advanced.Edwin Dirnbeck
    Oct 2005
    British Columbia
    Nice
    Did you have to weld on the 5/16" hex as well or do they come that way?
    I'm thinking a 1/4" hex is also popular for the smaller screw type hose clamps. Either way easy to adapt as would be a shorter or long driver shank.
    Thanks!
    Oct 2018
    NE Ohio USA
    Nice work and great solution. I love that.
    Best Regards,
    Bob
    Dec 2008
    Kendal, On
    Looks handy Ed, nice solution. I don't run into that problem enough to warrant making one, but I have struggled with the extensions and ujoint contraption before. The most annoying part is when you finally get it on the hose clamp, and get it loose enough that it rotates out of position and the socket falls off again.
    Feb 2011
    Nice
    Thanks!
    Yes ,It is a chopped of 5/16 high quality socket. I turned a short mating diameter on all pieces.I made them a slight press fit to hold them together . I carefully took them to a top quality tig welder.He did a good job ,I think.I originally made this for a very specific repeat job,but I find that it fits in many locations. Edwin Dirnbeck
    Feb 2011
    Never to be found again,Edwin
    Jun 2011
    Northeast, PA
    Nice solution but you can buy dedicated universal sockets that are much more compact than a stand alone with a socket on it. I own a few of certain sizes from my auto mechanic days.
    Feb 2018
    Asheville, NC
    Quote Originally Posted by oxford View Post
    Yeah baby, those are the ticket. My hangarmate had a set of 1/4" drive like shown. I was always into his toolbox borrowing them. I checked on the price of a new set ( 5 or 6 sockets). Over $200. Whew! I got lucky when he quit flying and sold them to me for 50 bucks.
    Bill Pendergrass
    Rotec RM-1 w/Rusnok head
    Atlas TH42 QC10
    Apr 2017
    Kelowna BC
    Did you try a simple 1/4 drive with a flex cable and screwdrive handle , i.e. flexible 1/4 drive ?
