Results 1 to 10 of 10
Thread: print your own T-shirts
    Chilliwack, B.C.
    Default print your own T-shirts
    Looking to print my own T-shirts. So far all I can find is 'send us your design and we'll print them for you'. What I want is the machine itself. I have read that you can ink jet them, or you can print the design to an iron-on transfer. It has also been suggested that with the right printer, you can deposit a 'heavier duty' ink, which has better lasting qualities.
    I'm in the beginning stages of this search, so I thought I'd ask here if anyone has had any experience with this. I don't have room for multiple stages of silk screen setups, so I'd like to stay with a direct printer of some kind. Presumably it would have a platen where you fasten the T-shirt down- maybe even with a vacuum hold-down- then you would deposit a suitable ink or colored solution, maybe require multiple passes for different colors- just a few guesses here.
    So far I have not found any links to the proper type of machine, though I'm pretty sure they must exist by now. Can anybody steer me?
    Aug 2018
    Loveland,CO
    Type "silk screen equipment" into your search engine.
    Apr 2017
    Kelowna BC
    I don't understand the no room for it but want to do it.
    I had a 4 station 6 color machine, no screens, that I would have sold this January and Feb, was down to 200 at the end.
    I took it apart for hardware, still have the plates and adjusters i think. It was /is 3 .5 hrs from you..
    It was a Blue Max 3.
    Mar 2003
    What you need is either a "dye sublimation" printer, or a "direct to garment" (DTG) printer, either one of which is going to cost you several thousand at least.
    Relevant link.
    Doc.
    If you're just making a couple, I've had good luck with these.
    https://www.amazon.com/Avery-Inkjet-...SIN=B0000C0CIR
    Apr 2016
    Second what Doc Nickel said, I've been looking for imagesetters to create negatives for exposing photo resists
    and came across these printers by Okidata, I think they're what your looking for, nowhere near as pricey as Doc's link
    but still pricey, smaller output size -
    https://www.oki.com/us/printing/prod...ers/index.html
    Oct 2013
    USA MD 21030
    Lightbulb
    Sometime ago I bought a pack of Avery transfer sheets for my inkjet printer, but never used them. I found professional T-shirt printers for about $16,000 - $60,000, but Amazon has some for well under $1000:
    https://www.amazon.com/digital-tshir...tshirt+printer
    Russellville, AR
    My daughter uses a Silhouette machine to cut designs from iron on vinyl which she fuses to t-shirts using a heated press. Don't know the make of the press. Can get vinyl that is suitable for decals such as car dealers use to put on vehicles.
    Jul 2017
    Springfield Mo
    Id just as soon go with silkscreening before i went for a machine. For simple patterns youd be more than set, multiple colors id wager you could do with multiple screens, one color at a time.
    That said, if youre trying to print a photo, silkscreening probably isnt the way to go
    Chilliwack, B.C.
    The T-shirt I'm wearing right now has rather blocky graphics on it, but the coloring is impregnated right into the cloth. The lines are sharp, and there is some pretty tiny printing on it that you can actually read. I'm sure the machine that did this is capable of decent imaging. You can feel the difference between the colored areas and the rest of the shirt, but there is no melted on vinyl. The cloth moves equally well over all its areas, colored or plain. This is what I'm going for since I also want the shirts to be comfortable.
