Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: OK, Convince me that A wedge Aloris type toolpost will work for me
    Default OK, Convince me that A wedge Aloris type toolpost will work for me
    Now, just to start with, I know hiow they work, I know the advantages, etc.
    This is a mechanical discussion, having to do with fitting it in place on the machine.
    background: I use HSS, brazed carbide, and carbide insert cutters up to and including 1/2" square, possibly a few 5/8". For ALL tools the cutting edge is at the TOP of the thickness, due to the type of 4-way post I use. I use some cutoff insert tooling that is 3/4" tall from bottom of shanks to the cutting edge, as well as whatever 1/2" HSS item looks like it will do the job of cutoff that I need done.
    here is the important part..... The distance from the spindle centerline down to the top of the compound is 0.912" on this Logan 200.
    AND, I already know that hanging the toolholder way out to the side so that it can go down next to the compound is a lousy idea, especially when I keep the compound at 29.5 deg. Because to clear the corner, it has to be just way way out off the compound.... even firther than if the compound were set with the travel at 90 deg to the spindle The thing that will be "compound" in that case is likely to be the leverage, particularly with a cutoff tool.
    So, is the thickness of the toolholder bottom going to preclude the use of the larger tools, and limit tools to just the 1/4" and maybe the 3/8" sizes? Are the 3/4" cutoff tools just too big, as it seems they must be?
    Because if so, that is a severe limitation that I would not pay money (i.e. buy a toolholder) to be subjected to. I have, and use, mostly the larger tooling, not because I really need the strength, but because that is what I have, lots of it, in HSS. brazed, and insert. Having to bin all that just to use a QCTP would not seem to be any great advantage.
    Hanging the holder off the side of the compound seems like a poor compromise, when it adds the better part of an inch overhang to the side. I prefer to have the center of pressure over the compound, even if there may not be actual direct-to-the-surface support under it. That keeps the "torque" applied to the compound to a minimum.
    Mar 2015
    If you are most concerned about rigidity and don't need to use the compound too often, a solid tool post would give you the most rigidity. A quality QCTP shouldn't be a factor
    Jan 2002
    Huntsville Ala
    I didn't follow through and analyze all of the dimensions you gave; but yes, you can easily find yourself unable to lower the holder enough to get the cutting point of a tall cutter down to the center line.
    For a 13" lathe the recommended QCTP sizes (the B and C) overlap. I first bought a C size for my lathe and quickly found the lowest height to still be too high for some tool bits. My local source let me exchange for the B size.
    It's too bad they don't make the dovetails in the holders the same size for all. Or at least those two.
    Jan 2014
    Long Island, N.Y.
    I have one of the AXA wedge knockoffs. The 250-101-XL tool holders I bought have a slot that's 0.640" high and measure 0.418" from the bottom
    of the slot to the bottom of the tool holder. So with the tool holder sitting all the way down onto the compound, the top of a 1/2" bit will be 0.918"
    above the compound or 0.006" too high.
    Sounds as if the 1/2" would be a bit dicey, some probably would not work, others might. And the insert cutoff tools would have to be tossed because the holders would not even take them..
    Not sure I would see that as a win, overall.
    If you are most concerned about rigidity and don't need to use the compound too often, a solid tool post would give you the most rigidity. ....
    That is what I have, basically, it is a solid block 4 way, not a ratcheting type, but the slots are each made up for a particular size cutter. There are 1/4", 5/16", 3/8" and 1/2", set up so the height is right, and there is no wobbly stack of packing needed.
    Some of the advantages of a QCTP could be of benefit, If I do not have to give up too much. But it seems from what I read here that I'd be forced to hang the holders off the side, and take the hit in overhung lever arm twisting the compound.
    Apr 2012
    NE Thailand
    Lantern tool post.
    With a threaded ring for tool location and height adjustment.
    Apr 2012
    Sydney
    I sat my tool holders on their side in the mill and ran a carbide cutter thru them to make the tool holder slots wider. Use carbide cause they are dang hard!
    Jan 2014
    Long Island, N.Y.
    Just a heads up Jerry. Both Shars and Precision Matthews list the dimensions of the 250-101-XL as follows:
    That suggests the distance from the bottom of the slot to the bottom of the tool holder is 0.938" - 0.625" = 0.313". Not even close to the 0.418" I measured.
    Here is someone who measured a pair of these holders in July of 2015:
    https://www.hobby-machinist.com/thre...97/post-319366
    Spoiler alert, they came in at 0.411" and 0.415".
    If you want to make this work for 1/2" tooling, I would suggest removing 0.030" to 0.050" from the bottom of the tool holders. It's a non-critical surface
    and you are only trying to gain a little clearance. If you want to make this work for 5/8" tooling, I think the amount of material you need to remove may
    start to compromise the tool holder (my opinion, no facts to back it up).
    Just to keep the "noise" down, this is the current toolpost, which is very solid and quite adaptable to most any task. The only reason I would change is to get an advantage in convenience without giving up much if anything in rigidity or size of tooling. (I use a different block for the insert cutoff tools or boring bars).
    The insert tooling shown in the post in the pic is 1/2", and the HSS in the other is also. I have lots of that size.
    I have no idea why I would change from this to anything other than some workable form of QCTP. This is stable, solid, and fits all sizes of cutters with no "packing". It does all the things that are needed for the "TP" portion of "QCTP", the part lacking is the "QC" part.
    I ran into a lighter weight version of the same problem with my own lathe and an Aloris style holder. My 12x36 has just 1.18" from center axis to top of the compound. So a slightly scaled up version of your problem.
    In a weak moment when I found a BXA sized Aloris clone piston tool post on sale for very cheap I also dove in and bought it. While it is listed as being the proper size I find it quite clunky and boxy. It's just visually in the way and when I use it I find myself always rubbernecking to see around it.
    And my buddy I'd reported on here earlier with a South Bend 9" has an AXA. On a smaller scale I again find that to be a bit clunky and boxy for the size of the machine. But it doesn't visually get in the way as badly.
    Like you're saying I'm also a big fan of keeping the cutting tip of the tool as close to being located over as much metal of the compound as I can. Likely for the same reasons. Those being reduced chatter risk and just a more solid and precise cut.
    My thinking is that for a Logan and similar size lathes that I think I'd go primarily for a maximum of 3/8" for cutting tools with square shanks used in the normal holders..
    For the bigger inserts and given our home shop options I think I'd go for custom made dovetail holders that directly mount the inserts. I'd either machine the insert pockets myself if the insert shape is not too extreme or I'd look at making holders without a lower shelf and attach cut down square shanks into the corner notch directly. Options for securing the square shanks to these open bottom holders would be silver solder, brazing, a bit of delicate TIG or screws.
    Due to how hard some shanks are screwing them into place would likely require buying a couple of solid carbide drills or drills and counter sink. For up to 1/2" shank I'm thinking a couple or three 10-32 screws. For larger I'd go with 1/4-28.
