Results 1 to 10 of 34
Thread: 5C collet for lathe
    Mar 2010
    Metro Detroit
    Default 5C collet for lathe
    When I bought my Clausing 5914, it had a Royal collet closer attached to it. I had never seen / used collets before and to reduce the buy price the used machinery dealer stripped off the closer (in hindsight one of my worst $100 savings).
    I have since used collets a few times in a Hardinge HLV-H - what a dream machine. Now I want to add 5C collet capability to my lathe - I already have a Jacobs rubber flex collet chuck and collets though I tend not to use them that much.
    My plan was to make a drawbar style collet closer. How much torque is needed to tighten the closer - will I need to plan on a pin spanner wrench? I acquired a mystery collet closer for a starting point. My concern is machining/grinding the mating tapers. I have no taper attachment so I am presuming to offset the tailstock. If I modify one of my existing parts either machine a 4.5 MT to the OD of the existing collet chuck or machine out the ID of the 4.5MT ODx3MT ID adapter I have to mate with a 5C collet, I need to figure out how to hold these parts and be able to machine either the OD or ID. I have never (intentionally) machined a taper. I have a simple/crude tool post grinder to finish the surfaces (if I can get the taper correct).
    The other option is to buy a collet chuck. I read the recent thread http://bbs.homeshopmachinist.net/thr...huck-s-Closers and looked at the link for the Gator brand 5c collet chuck. That is currently more than I am willing to spend for something that is a "want to have". I have seen cheap import 5c collet chucks for under $150. If I were to mount one of the cheap 5c collet chucks on a backplate so that I have radial adjustment (like an adjust-true chuck), is there a hope that I could end up with a reasonably repeatably concentric collet chuck? To me reasonably repeatable would be say 0.0015 or slightly better. Anyone have experience with the cheap China collet chucks? The cheap 5C collet chucks seem to run about $135 or so - here is one with the L-00 backplate that I would need: https://www.ebay.com/itm/BOSTAR-5C-C...ox!60639!US!-1
    Mar 2010
    Metro Detroit
    Images below are: my lathe spindle with 4.5 MT bore, hand wheel where the drawbar end would mate and two views of the parts available to modify to make a drawbar closer.
    Sent from my 5049W using Tapatalk
    Jan 2007
    Minnesoa
    Hi,
    I bought a cheap and cheerful Chinese 5C off of eBay and mounted it to a back plate that I could "tap" in for runout and it works great for me. Once adjusted, I still get just a bit less than .0005" runout on a 1/2" dowel pin. Dismount and remount on my 8x14 is very repeatable so far.
    I hope you didn't take the taper attachment off for another $50 yup, worst $100 you ever saved. You've got a MT 4 1/2 spindle? Perfect for a 5C adapter and collets right in the spindle are the best set up. The tapers needed are not long so you could do them with the compound. There was a day I'd have not even thought about outsourcing it, but nowadays its just more on the the todo list so might look at what someone with a cnc would charge to knock one off. Or knock 5 off, sell them on ebay and get yours for free. A HT chrome moly ought to be sufficient, but if you are outsourcing, hardened and ground would be really nice
    Mar 2018
    It would probably be easier to buy one like this one and then lengthen or shorten the tube as needed. This is just a result of a quick Ebay search. I love my Royal collet closer. They are hard to beat.
    https://www.ebay.com/itm/ROYAL-15-5C...UAAOSw7PFdOaME
    Not sure what you have that can be used. But in my case I made up all the parts shown below and the second pic shows the collet chuck in use.
    I needed the nose extension in my case because my lathe has a gap bed. And the filler does not extend all the way to the head stock. So I needed the extension from the head as shown. And the chuck portion actually screws onto the spindle threads and tightens in place with the G wrench shown.
    Tightening the chuck itself and the drawbar to hold the work is just a couple of medium palm bumps once snug. No need for any sort of extension pipe. The wrench shown is 11" long overall. Literally 10.5 from "hook to hole". So clearly it doesn't take a gorilla grip to hold stuff in the collets.
    The hand wheel on the drawbar is the same OD as the fat end of the chuck itself.
    Atascosa County, Texas
    I'd get that 5C collet chuck in a heart beat. It comes with a back plate.
    The only drawback I see with mine is the long winded screwing to tighten. I cured that with a driver that fit the pinions.
    Mar 2011
    Troy, Mi
    Quote Originally Posted by aribert View Post
    I say forget about 5c. You can't buy enough collets to make it complete. Also stand out from the spindle is significant. Go with ER50 or 40 at the minimum. One set of collets covers every diameter out to around 30 mm. No draw bar required and a far better grip than 5c. I made an er40 chuck for my 10" Logan. Collet set covers 3-28mm. Bumped the upper limit many so many times, wish I went to er50.
    You would be amazed at how smooth cut offs go usually at ~1/2 the speed used to turn the part. Made an er40 chuck for my 7x14 mini also. Can't do that with 5c. You will have to buy the closer nut. Get the bearing style not the plain nut.
    Jun 2011
    Northeast, PA
    If you do go 5c, you should make a collar that goes over the external spindle taper that engages the threads that hold the chuck on. You then use this to pop the 5c adapter out of the spindle.
    There was a manual collet closet on the Clausing 6300 lathe at a place I worked and it had a shop made wheel on the end around 8” in diameter. It seemed to be fine for torque on the collet.
    A lever closer is worlds above a manual closer for speed if you have a bunch of parts that you need to run off. You don’t even have to turn the machine off for parts chanes.
    Jul 2006
    I think there is a company called JFK Products or JFK Precision who sell 4 1/2 Morse to 5C adaptors.
