Results 1 to 10 of 26
Thread: John Deere vs Steam - This Is Great
    Default John Deere vs Steam - This Is Great
    Saskatoon, Saskatchewan
    Not really that great. The difference in height between the two tractors drawbars means the the JD tractor's rear end up is lifted up while the stream tractor's rear end is pulled down.
    Apr 2009
    Quote Originally Posted by Arcane View Post
    Tractor people always say that!
    Jul 2006
    Dracut, Massachusetts
    I wonder how those two tractors match up horsepower-wise. And needless to say, that steam tractor looks to have a significant weight advantage. The guy in the JD tractor might want to be in 4WD mode next time, but it probably would not matter. It would be good fun to see this in person, in any event.
    Atascosa County, Texas
    Is there supposed to be a video in that link?
    I buried my Ford 3910 up to the rear axle and pulled it out with my 20hp "Johnny Popper". The JD will also push a 5-ton pile of dirt without breathing hard.
    Oct 2009
    when an 8 year old makes the fist in the air pumping "blow your whistle" signal, the modern tractor got nothing.
    Feb 2005
    gettysburg pa.
    you know what they say about j-d tractors?
    they leave the red and gray tractors for us that know better.
    Aug 2018
    Northern WI
    Hmm, a Johnny Popper with 20hp and pushing dirt piles, I'm going to guess maybe an MC or 40C. How'd I do?
    Oct 2009
    Ontario, Canada
    The big difference is that the steam tractor can apply maximum horsepower at ~0rpm, while the JD will need to be in his power band to maximize horsepower. That lets the steam tractor walk away through massive torque at a low wheel rpm (no slip, static friction) while the JD spins against it also with high torque but with the wheels spinning (slip, sliding friction). If you were to gear the JD down to the level where you'd see the type of torque at minimum rpm it would be a much different contest.
    Quote Originally Posted by Galaxie View Post
    Close. It's a 1956 420C. (Tracked crawler/dozer) It spent it's working life as a pipe layer so it has a front blade, boom on the left and counter weights on the right.
