Results 1 to 10 of 36
Thread: Diagnosing car issue - AC blower
    Mar 2015
    Default Diagnosing car issue - AC blower
    My final thought is that the front blower motor is drawing too much current.
    Here is the backstory:
    8 months ago I replaced the resistor that controlled the fan speed. Fixed the problem. 3 months ago problem came back intermittently. Ordered a new resistor to replace when I got around to it. Few weeks ago, the switch on the front panel failed. This switch directly switched on the current to the motor through the resistor to the blower.
    Just replaced the AC panel and switch. Fan still doesn't work. Just went to replace the resistor pack and discovered this...
    The plug from the blower to the resistor.
    So I ordered a new blower assembly for 60$, only thing I can think of that would be killing components. Sound good?
    winnipeg
    A plugged cabin filter causes an air restriction, which then causes the resister to overheat and melt.
    They have filters in auto ACs? What makes and models have that?
    And more to the point, where are they? How do you find them?
    Quote Originally Posted by amateur View Post
    Nov 2008
    SF East Bay.
    I've seen them in different places. Some have them in the cowling at the base of the windshield (a Cadillac) and others behind the glovebox (two Toyota models).
    Mar 2015
    In the Kia Sedona, the front blower resistor is located in the airstream duct, downstream from the blower, below and to the left of the glove box.
    The cabin air filter was placed upside down and was dirty. Can't trust anyone to do your mx.
    Mar 2015
    Central Ms
    Honda Odyssey cabin air filter is below the glove box.
    Lewis Grizzard
    Mar 2015
    Either way, no A/C in Florida is the equivalent of no car.
    Mar 2015
    Old and new resistors are testing the same... unless they are both bad and I haven't found the new one yet...
    Leads of my multimeter measure about 0.4 ohms. Both test about 0.7, 1.2, and 2.4. Highest speed must be straight battery voltage and doesn't go through the resistor, as there is no connection for that on the resistor. Time to extract the blower fan...
    Feb 2016
    Edmonton, Alberta, Canada
    I know on GM trucks, it's not unusual for the connector to melt like that. They seem to have selected connectors that just barely meet the power requirements of the connection (same with the connectors to the DRLs).
    Jun 2004
    N.J.
    One typical presentation of this issue is the blower fan bushings wear, causing drag and increased current. The resistor eventually burns out and you only have one fan speed. The wear progresses to the point where the fan starts to howl and/or takes out the switch contacts as well from the increased current.
