Results 11 to 20 of 39
Thread: 3 Phase motor noise?
    Mar 2015
    You need to be pretty old or deaf not to hear 12khz whine. At 40 my hearing sensitivity seems to fall off at around 15khz.
    And I have like worst hearing amongst my friends. I remember when I was in twenties the CRT television line frequency whine @ 15.6khz was audible just barely when some of my friends were going nuts with the whine.
    Aviation hasn't been kind to my hearing
    Helsinki, Finland, Europe
    Yeah, I was about to mention something about that those turbojets/fans/props might have something to do with it in your occupation.
    Atascosa County, Texas
    I don't hear the whine either but I sure hear the gravel in the chain drive! What the heck is that?
    Feb 2019
    Wisconsin
    I think you are hearing a rattle that is in the coupling going to the power draw bar, I have to look at that yet. Its belt drive variable speed.
    Woodinville, WA
    Quote Originally Posted by Mopar_Mudder View Post
    I did check the specs on my VFD and it has no derating for the higher frequency, it will go up to 15.0. Also just wanted to make clear the VFD make no noise it is just the motor.
    Not the VFD... the motor is affected by the higher carrier frequency. Goggle is your friend.
  6. #16
    Woodinville, WA
    At 66 (nearly) mine is shot in the 5-8K range, then dies off at 12k to nothing. Shrill women still get my Attention.
  7. #17
    Nov 2008
    SF East Bay.
    My inverter rated motor had a wicked whine when I first set it up. I thought the bearings were bad. I changed the frequency and it went away. I found that it was dead quiet when I went back to the original value and changed it just 10% or so. In my case the problem appeared to be a resonance within the motor.
    Dan
  8. #18
    Jul 2014
    Southern Indiana
    MoparMudder: Is this a used machine? To me, it sounds like worn stuff in the variable drive. Try changing the spindle speed while it s running. Changing the spindle speed while running from the slowest speed to the highest speed, may show areas where there is no or very little rattle.
    Sarge41
  9. #19
    I didn't mean anything by my comment. Noisy machines are often referred to as "rock crushers", "chain drive" or "thrashing machines". That video ranks right up there with the best of them. I hope it's just your drawbar rattling around in there but if it is, it may be bent or missing a washer. That sound is not normal
  10. #20
    Feb 2019
    Wisconsin
    Thanks for the feed back, I really don't know what it should sound like being my first mill.
