Results 31 to 39 of 39
Thread: 3 Phase motor noise?
  1. #31
    Jan 2013
    Michigan
    I have shielded 3 phase motor cable connecting my my hitatchi vfd to 2.2kw Chinese spindle. I wonder if filtering would provide any benefit, or additional quiet? I also added a screw to ground the motor case to the vfd.
  2. #32
    Mar 2015
    Quote Originally Posted by Glug View Post
    Hmm, I am now wondering if running my 1950's Bridgeport pancake motor off the VFD is a good idea without an output reactor?
  3. #33
    Woodinville, WA
    Cheap peace of mind...
    Or move to high end ($$$) VFD like ABB ACH500 series - the output inductors are built in.
  4. #34
    Mar 2015
    The sad thing is since installing the RPC, I kinda want to run it off the RPC directly. But it is a step pulley so the VFD will stay.
  5. #35
    Aug 2004
    Sunny So Cal
    That's why they sell "output inductors" (common in industrial installations, commonly ignored by HSM ). .
    Come on now. It is an Machining forum. Not the lightning bolts of electricity Forum..
    Some of us don't get the electrical side. I m square with that.JR
  6. #36
    Mar 2010
    [QUOTE=RB211;1252033]Hmm, I am now wondering if running my 1950's Bridgeport pancake motor off the VFD is a good idea without an output reactor?[/QUOT
    My BP's pancake motor has been on a VFD since I got it in 1995. No reactor and no problems.
    RWO
  7. #37
    Apr 2010
    Spotsylvania, VA
    Page 2 of the document linked below talks about output reactors. It sounds like you should not need to worry about this if you motor wiring is less than 100 feet long.
    https://www.rae.ca/wp-content/upload...r%20AN0032.pdf
    Tom
  8. #38
    Woodinville, WA
    Don't take that to the bank; there is no "one size fits all". In any case, if you want to "quieten" the motor (getting back to the the original post), simply increasing the carrier frequency until you can't hear it is often not the right choice, but an output reactor nails it. Do you really need it? Probably not in home shop environment, but it sure doesn't hurt.
    Seeing we are taking about vfds, another issue ignored is the "noise" currents flowing though the rotor via the bearings to ground; significant decrease in bearing life. Output inductors help, there are bolt on brushes to retrofit older motors, and circular brushes at the shaft are now installed by some manfs on inverter duty motors. I'll dig out the info tonight.
  9. #39
    Oct 2013
    USA MD 21030
