Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 72
Thread: Ethanol in pump gas damages 2 cycle engines..???????
  1. #31
    May 2006
    I like 10% --- it's a great octane booster and makes fuel burn much cleaner,,, but that's my limit - im against 15% and yet that's what we are going to this summer everywhere due to --- oh, well im not going to get into that cuz it will open a huge can of worms...
    but again - 10% gets me free equipment cuz people freak out the first time their stuff don't start...
  2. #32
    Jul 2006
    Dracut, Massachusetts
    Quote Originally Posted by mikegt4 View Post
    pure-gas lists 26 locations in the People's Republik of Massachusetts that have ethanol free gas. Admittedly some are old listings but at least a dozen have been confirmed within the last year. You may have to travel a bit but filling a 5 gallon can will last all year. Interestingly, the corn producing states seem to have a lot of ethanol free outlets.
    https://www.pure-gas.org/index.jsp?stateprov=MA
    Thanks, Mike. I have seen that listing and almost all of those are selling the VP Racing stuff that I can get at any NAPA parts store or lots of hardware stores in quart and gallon cans. It's the stuff I typically use anyhow. The only one close enough to make it anywhere close to being worth the trip is selling leaded racing fuel from a pump and it was ~$10/gallon in Jan 2018. There is a listing for an airport that was selling hogh octane non-ethanol stuff but it'd be a 2+ hour round trip and just not quite worth the trouble in the quantities I use.
    I do appreciate the info!
  3. #33
    Oct 2013
    USA MD 21030
    I had many problems with my Poulan Pro chainsaw, possibly caused by ethanol, but I have always used the premix cans for that. It was always hard to start, then I was able to tweak the hi/lo mixture screws to get a little more use out of it, but eventually it just became a biceps builder and sweat generator. I bought a new carb and rebuild kit, but never installed it. Instead, I bought a 16" Echo lithium chainsaw which starts instantly whenever I need it and runs quietly and cleanly. I also have a battery powered trimmer, but it's an old B&D SLA version which is heavy and only runs for 15-20 minutes. But I also have a corded trimmer which does the job for me. The newer lines of lithium powered tools are approaching the point where gas powered tools may be obsolete and inferior.
    The generator I bought recently runs on propane, which avoids the problems with ethanol in gasoline, and it also burns cleaner. It should, anyway - I haven't used it yet. Perhaps they will make 4 cycle chain saws and trimmers that run on propane?
    https://www.survivalistboards.com/sh...d.php?t=365719
    https://golehr.com/propane-powered-l...rden-products/
  4. #34
    Quote Originally Posted by PStechPaul View Post
    There are already have 4 stroke trimmers that I see no reason why you couldn't run on propane. They have 4 stroke chainsaws as well but they still use an oil mix, so that is still problematic.
    Quote Originally Posted by nickel-city-fab View Post
    On a somewhat related note, I have been wondering how older Diesels (Detroit, etc.) survive with the low sulfer crap now days.
    Fuel Additives. Unlike the hard-to-remove ethanol, it's easy to add stuff. A fellow on YouTube named Scott (Grease Bus Monkey) puts about 40k a year on a Detroit Greyhound bus driving around fixing other Detroits. He is probably a decently reputable source if you need info on that.
  5. #35
    Oct 2013
    USA MD 21030
    It looks like the Lehr propane tools were a flash in the pan, and they are no longer available. Too bad - seemed like a good idea. I would like to try converting a weed trimmer to propane, but the three junk trimmers I have are two-cycle, and propane needs four cycle. There aren't many old junk 4 cycle trimmers, and new units are rather expensive. Here is a video of a propane weed whacker conversion, but it is only part 1, and it ended without fixing the problems of fuel mixture, speed regulation, and other issues.
    Apparently never got it running. Part 2 is converting it to run on water: https://www.youtube.com/watch?v=5aV1Aooakos
    Part 3: https://www.youtube.com/watch?v=mtGd5cupSMg (start video at 5:15 to see an epic FAIL!)
    I'll stick with electric machines
  6. #36
    Feb 2016
    Edmonton, Alberta, Canada
    Propane for a weed whipper doesn't seem like a good idea, as propane is less powerful than gas (per unit volume), so you need a bigger tank, the tank needs to be made of metal, so it's also heavier, and you'd want a special pickup tube in the tank, so it only gets the vapour (with a regular tank, if you invert them, you get liquid out, and weed whippers can be used in a variety of orientations).
  7. #37
    Nov 2010
    Northern NY
    I don't currently own any small engines old enough for E10 to negatively affect, my oldest is a '97MY by which time manufacturers had the issues pretty well figured out. When fuel gets to be ~6-8 months old I either dump it, pump it, or run it low depending on tank size and refill with fresh as after that you're running the risk of causing issues if sucked into a fuel system regardless if its E10 or not. If its a rarely used item like my old snow machine then it gets topped off and STABIL added, then after two years I dump it, pump it, or run it low. For rarely used smaller two strokes the better pre-mixes are usually good for at least a year IME.
  8. #38
    May 2006
    Quote Originally Posted by justanengineer View Post
    We've got about the same practices --- the only thing to fear is fear itself, or becoming such a neurotic about "anti-ethanol" that you make things way worse than the ethanol itself...
  9. #39
    May 2015
    I purchased a Still chainsaw last year. I had fuel mixed up out of E90 regular gas and it would not run. Took it back and was shown the problem so I changed to non ethanol gas. In fact on my push mower I have a cut off and run the carb dry as an extra precaution
    Sent from my iPad using Tapatalk
  10. #40
    Oct 2005
    British Columbia
    If it has a carburetor and a vented fuel tank it is old enough to be affected.
    Small engine manufacturers still loath E10 but are forced to accept it, E15 causes convulsions in the board rooms.
