Results 1 to 10 of 11
Thread: Boxford headstock spindle bearings?? Where to find?
    Aug 2008
    Toowoomba, Qld
    Default Boxford headstock spindle bearings?? Where to find?
    BOXFORD VSL500 I think.
    Bearings in headstock are shot, where can I find new bearings. Can't seem to have any luck at all searching with google etc.
    Dec 2002
    Friesland, Netherlands
    You could try the manufacturers: https://www.boxford.co.uk/support
    Or maybe this guy has something: https://www.ebay.com/itm/BOXFORD-LAT...0AAOSwLx1awizq
    Ian
    All of the gear, no idea...
    Sep 2011
    Langley, British Columbia
    What kind of bearings are they? Roller bearings? Tapered rollers? Plain bronze? Having more info would
    be a big help...
    Keith
    __________________________
    Aug 2012
    Warwickshire, UK
    Quote Originally Posted by apples View Post
    In what way are they 'shot'? Have you stripped the spindle and inspected them? Often, all that 'shot' taper roller bearings need is a really good clean, (I had to wash my Raglan's taper roller bearings out 6 times with white spirit before they were clean) oiling or greasing, and reassembling properly adjusted with the right amount of preload. If they really are shot, once you've got them out you can see the makers reference numbers which might make your search easier.
    Tony at www.lathes.co.uk offers a manual and parts list for all the models of Boxford including the VSL.
    Jun 2003
    Calgary Alberta
    The Boxford section at lathes.co.uk states that the spindle bearings are the same as the wheel bearings foe some unstated UK made sports car.
    Aug 2012
    Warwickshire, UK
    Quote Originally Posted by quasi View Post
    Where does it say that? I've just read a lot of stuff on there, and generally it seems that Boxford used Timken, but the VSL had a different larger spindle and maybe Timken or Gamet 'Precision' - expensive, but it isn't clear. Can't see any reference to sports cars.
    May 2015
    Somerset UK
    Simply bearings in the UK sell Gamet taper rollers, they are expensive.
    https://simplybearings.co.uk/shop/Ta...461/index.html
    Aug 2008
    Toowoomba, Qld
    update.
    Well so far I have taken off the two drive belts. The spindle is noisy but nothing like what it was like. I think they say the boxfords are a little noisy. I just spun the chuck up with a drill to see how loud it was.
    It's the saddle bearings on the intermediate shaft that shot.
    https://streamable.com/8ufa8?fbclid=...cqH-oI67p21KUQ
    Aug 2012
    Warwickshire, UK
    Well at least that will be cheaper than spindle bearings.
    Aug 2008
    Toowoomba, Qld
    Well I am not out of the woods just yet. I still don't know what the spindle bearings are like. Trying to work out how to remove the chuck. I have started another post on that too.
