Results 21 to 30 of 38
Thread: Boxford vsl 500 what is this screw for? How do i remove chuck?
  1. #21
    Aug 2012
    Warwickshire, UK
    Mr Apples-
    I told you in post 3 you were turning it the wrong way! The nut is captive on the spindle. It stays on the spindle when the chuck comes off.
    Lets hope all your efforts haven't made it really difficult to get off now.
  2. #22
    Dec 2002
    Friesland, Netherlands
    As others have said, the nut & backplates have right hand threads, so you're tightening it, not slackening it off.
    The taper should be really tight by now
    Ian
    All of the gear, no idea...
  3. #23
    Aug 2008
    Toowoomba, Qld
    Well I will have to try the other way then, lol.
    Just that the thread to me looks like the nut would screw on clockwise to tighten up. Therefore I would need to pull downwards on the lever to make it unwind anti-clockwise.
  4. #24
    Aug 2008
    Toowoomba, Qld
    Hang on. Yes the way I just said is correct, regarding the threads. But that nut does not unwind fully and go towards the chuck.
    Richard, yes, now if I think about the nut from looking at it from the left side. Pulling down on the bar will tighten it, pushing up should loosen it.
  5. #25
    Mar 2008
    You want to be either pulling up, or pushing spanner away from you. Put some protection on ways, as spanner tends to hit them when nut comes loose.
    The set screw deal is a non factory modification.
    The plunger just up and to the left is the spindle lock.. if it's working, no need for gears to be engaged ( and better).
    I have a 500 VSL.
  6. #26
    Aug 2012
    Warwickshire, UK
    Oh good, an actual 500VSL owner. Hopefully you'll be able to give the OP some sound advice when he comes to take the spindle out to inspect the bearings.
  7. #27
    May 2015
    Somerset UK
    Obviously the OP didn't look at the link in my post#4, or understand the drawing. I can imagine what is going to happen to the poor bearings.
  8. #28
    Aug 2008
    Toowoomba, Qld
    Hey, I got it off, whoo hoo!
  9. #29
    Aug 2008
    Toowoomba, Qld
    That threaded section with the notch in it actually freely spins around the shaft. It's just there to lock it to the big chuck retaining nut. Now I know.
  10. #30
    There is one word that was missing from this thread:
    KROIL
    Doesn't anyone oil things anymore?
