Results 1 to 10 of 21
Thread: Carbide end mills, short life
    Feb 2007
    Arkadelphia Ar.
    Default Carbide end mills, short life
    I've had my mill for some time now, an XLO. My question is about a lack of longevity with end mills. I'm using a mister for cooling and looking up feeds and speeds with FSWiard but seen to loose the edge off of end mills quickly. What am I doing wrong. My latest project is making an follow rest for my lathe, 1018 mild steel, 3/4" carbide 2 flute end mill running at 1000 rpm and .100" depth of cut, probably running at 1/2 to 3/4 of feed rate, three passes in and have lost the edge on the side of the end mill. The coolant is cool mist 77 I think. I am open for suggestions. Thanks
    Mar 2015
    Are you slotting? Poor chip evacuation will do that. XLO looks to be a very stout machine so ruling that out unless you are using poor workholding methods allowing the part to flex or move.
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by quadrod View Post
    I am only gonna trow a shot at it so... 3/4" or 3/8"? That is a massive chunk of carbide. In two flute. Prolly 3/8 assuming
    The two flute deal. Thats an aluminum bit. You really dont need to go esoteric with Carbide Endmills. Center cutting or not? Two or four flute.
    Try a four flute with center cutting, I like center cutting endmills, I wont buy the other stuff cause I am not a factory
    Oh!! And lay off the cooling for the carbide, you will fracture it.
    Helsinki, Finland, Europe
    Climb milling or conventional milling?
    Chip re-cutting or chatter are most likely causes. Or excessive runout.
    Feb 2014
    No, not really. 2 flute is good for aluminum, but that doesn't make it "an aluminum bit". They're good for steel as well, and highly recommended over a 4 flute for slotting. He's not running a production shop obviously, so the additional feed rate capability of a 4 flute doesn't really matter.
    quadrod - are you taking a cut and then bringing the cutter back over the cut for the next pass so that it's just skimming the fresh cut? That can chip edges of carbide end mills; it's better to either step the part away from the cutter for the return pass, or take a shallow cut. Dwelling at the end of a cut can do the same thing. If you eliminate those two things, your carbide should last a lot longer.
    Montvale, NJ
    Forget coolant with carbide cutters in steel.
    Cutting too slow is no good with carbide either. You want nice blue chips coming off the cutter. The blue color indicates that the cutting heat is being removed with the chip and not staying in the cutter. Sometimes being more aggressive with carbide is better.
    Oct 2006
    Ivins, Ut
    Unless its only moderate cutting, I use coolant almost all the time with carbide inserts. It greatly extends the life of the insert and in some cases improves chip control. There is no danger of fracturing the cutter if the coolant is continuous, and started when the cutting starts.
    For the OP: I use a mist coolant system too, but I use relatively low air flow and 'sputter' the coolant unless higher air flow is needed for chip clearing. You didn't give specifics on the brand of endmill or your actual feed rate. Quality can make a huge difference in performance and durability. Personally, I'd slow a 3/4" 2-flute down to 800 rpm and try again.
    May 2015
    Somerset UK
    You will chip solid carbide cutters if you touch on to steel with the cutter stationary.
    Feb 2007
    Arkadelphia Ar.
    3/4" 2 flute, first pass was a slotting pass, did 3 slotting passes for a depth of .300", then two side milling passes to widen slot. Brand in this case was kodiak cutting tools, no coatings, feed rate was may be 1 to 1 and a 1/2" a min. The mister I'm using is one I made my self, one tube inside and outer tube, air flows through inner tube, coolant flows through outer tube so it throws droplets onto cutter/work piece. A needle valve can adjust coolant flow.
    Feb 2007
    Arkadelphia Ar.
    Also I did not have a 4 flute cutter available this time, carbide is expensive.
