Results 11 to 20 of 27
Thread: OT: Low voltage digital circuit and shielded cable
    Jan 2006
    Grounding the shield at more than one place can lead to AC currents in the shield, which can couple into the signal conductors. If a design requires grounding at both ends, maybe they are using the shield as a signal return.
    Ed
    Nov 2013
    SF Bay Area
    Quote Originally Posted by QSIMDO View Post
    STEADY ON, lads!
    Motorcycle, 12 volts DC...I'm using a "Motogadget m-unit" if anyone's interested and a V.2 not the new blue tooth doo-dad.
    If I don't ground the shield would it be just the same as running separate wires or is the problem the twisted pairs in there are in close proximity?
    Your thread wandered a bit, didn't it?
    You'll have no problem with ground loops (an AC phenomenon), no problem with RF interference (it's not avionics), in fact you'll have no problem at all.
    DC in those wires will not be bothered, and any switched/pulsed signals are in the audio range so capacitance is negligible.
    Ground the sheath or not - whatever is convenient.
    -js
    Nov 2013
    SF Bay Area
    Quote Originally Posted by ed_h View Post
    Ed
    Ummm, the AC you speak of would come from what source, Ed?
    -js
    Woodinville, WA
    For your motorcycle use... forget the shield and ground. Yes,m it will behave just like unshielded cable. Don't worry about the effects of twisted pairs either - you don't have balanced input/outputs.
    Dec 2018
    +1
    absolutely.
    shields are over rated, and over engineered
    just wire it up and go for your bike ride
  6. #16
    Ct
    Thanks one & all!
    Better answers here than I've ever got on bike sites.
    I guess they just ride.
    Len
  7. #17
    Woodinville, WA
    They are smart!
  8. #18
    Ct
    They are smart!
    That's why we own more than one!
    Build, ride, repeat.
    Len
  9. #19
    Dec 2012
    It's a bad idea to leave a shield floating. This will cause the capacitance of the cable to change depending on the signal passed through it.
    Will it cause problems with low-frequency digital signals on a motorcycle? Probably not, but it's almost as easy to tie the shield to ground as it is to ignore it....
  10. #20
    Jan 2006
    Quote Originally Posted by Jim Stewart View Post
    -js
    In General, the most obvious source is the power grid. Pick two random ground points and there is likely to be at least some AC potential between them. Connect them, and you have an AC current. Varying potentials from atmospheric phenomena, like storms, would be on top of that. These examples assume true earth grounds, but the same principles apply in systems isolated from earth. On a car or motorcycle for example, there can be a number of AC noise generators, like the ignition system or electric motors. The noise gets into the chassis "ground", and it's potential can vary from place to place.
    Ed
