Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: What "advanced" metrology gear do you have?
  1. #41
    Jul 2005
    Chester, NH
    Sliding calipers (vernier, dial, digital)- yes
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Sensitive (.0001"/.001mm) test indicator- yes
    Telescoping gauges- yes
    Small hole gauges- no
    Bore micrometer- yes
    Granite or iron surface plate/table - yes 12x18 and 24x36
    Sliding height gauge- no
    Height tester - yes
    Precision test centers - yes (shopmade)
    Reference square - yes, several
    Gauge block set - no
    Gauge pin set- no
    Sine table or bar- no
    Master level - yes
    Machinist's level - yes
    Thread wires - yes
    Thread gauges - yes (some, not a complete set)
  2. #42
    Apr 2012
    NE Thailand
    Sliding calipers (vernier, dial, digital)- 4
    Micrometers- 5
    Dial gauges- 5
    Test indicator- 1
    Sensitive (.0001"/.001mm) test indicator- no
    Small hole gauges- yes
    Bore micrometer- yes, internal mic 2 - 8"
    Granite or iron surface plate/table - yes 24 x 36 in
    Sliding height gauge- yes, 24" Chesterman
    Height tester - no
    Precision test centers - no
    Gauge block set - yes
    Gauge pin set- no
    Sine table or bar- yes
    dial bore gauge - 2-6"
    Mit combo set
    Russian knock off vernier protractor
    High end Vickers precision level
  3. #43
    Aug 2004
    Sunny So Cal
    I am a tool hound. I love weird tools.
    This one was weird to me. Its almost like a joke piece. No way this thing could hold any dimension.
    Three foot tall Starrett square.
    Yes. love you guys are tool folks. JR
  4. #44
    Beaverton, OR
    Old Interferometer, it will measure distance down to a millionth without any issue. Other attachments can measure angular deflection, flatness, etc. I was able to measure the backlash in a starrett micrometer head in the lower pic. I have a newer one that should be able to do down to .3nm. These are often used to map ball screws on cnc machines, also they are used for positional feedback instead of encoders on machines that work with ICs on semiconductor wafers.
    Untitled by Jerry Biehler, on Flickr
  5. #45
    My list of metrology items is severely lacking. I started to acquire Mitutoyo outside mic's, and buy as I need something. No sine bars, no gauge blocks or pins. Do have a surface plate and height gauge. A couple of crappy HF calipers, and a set of tiny telescoping gauges that I suspect are fake Mitutoyo from Amazon as they feel Chinese with a Chinese or Indian finish.
    as generations of brilliant and skilled model engineers have shown, you don't need a ton of fancy expensive equipment to turn out incredible work. But it is a heck of a lot fun and makes it easier/faster. i think I have everything mentioned in this thread plus tons more, I think I've 22 boxes at the moment plus lots on shelves. Well, I don't have an interfermoeter, it was no brainer macona would win measuring measuring contest. I did get to use one very neat. One practical use is a cheat for a carnival weight guesser - you can get within a few pounds by measuring concrete slab deflection when someone stands on the spot. The owner of it is a nut job so so don't play with it anymore....other the cool factor, not sure when I'd do with it. They're not hard to use but irrc, you do have to worry about/compensate for air density, and of course when you measuring millions temp matters. I've 1/100,000" mechanical comparator as well as a federal 1/100,000" indicator but passed on the 1/1,000,000 comparator (was in Spar, used to sort balls for the bearings for the Canada arm). Other than curiosity/pride of ownership I just couldn't conjure a use for it
    I was looking through the thread thinking I bet no one has a 36" square.....and then JR posts a pic! too funny, couple toolaholoics to have crap like that kicking around.
    Of course 99% of time its all covered off with a couple of mics, digital caliper, dti, telescoping gauges, depth mic, square and maybe small hole gauges....but its been fun wheeling and dealing and collecting the tools. Its only hoarding if you don't use them
  6. #46
    Aug 2016
    Appalachian Ohio
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Bore micrometer- no
    Granite or iron surface plate/table - yes 36 x 48
    Height tester - yes
    Reference square - yes (shop made)
    Gauge pin set- no (.250 - .500)
    thread micrometer - yes
  7. #47
    Beaverton, OR
    LOL, I do have some shiny toys. The cards for the other interferometers are VME so I have to figure out how I am going to talk to those. Fun.
  8. #48
    Quote Originally Posted by Rich Carlstedt View Post
    Too repeatative I think, so how about additions to your list.
    I didn't see these I believe so I will list some additionals I have
    Precision Square (Starrett)
    Precision Level (Starrett)
    Cylindrical Square
    Gear Measuring Pins ( Van Keuren)
    Gauss Meter (Magnetic measurement)
    Surface Finish comparator
    Rich
    So you have at least one of all the other things on the main list? I was looking at the initial list as being items to tabulate for the results in my first post. I'll leave out your entry until this is confirmed.
    The lower list in the first post is tabulated up to this point.
  9. #49
    Jul 2002
    IO got a stick with marks on it.
  10. #50
    Nov 2013
    SF Bay Area
    BC, when you listed height tester I gather you meant what I know as a surface gauge. Sure, I've got one of those.
    One other thing I remembered - ten or twelve years ago a friend gave me a box of tools that had belonged to his grandfather. One nice item was a mechanical tachometer (Starrett). It has various size contact wheels that you touch to your rotating work or tool.
    Works fine, but I don't know why anyone would want one now instead of a simple electronic tach.
    -js
