Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: What "advanced" metrology gear do you have?
    Default What "advanced" metrology gear do you have?
    I see folks in various threads suggesting the use of sine tables or bars or gauge pins and blocks for various task solutions. So I'm curious as to what folks have managed to buy or make along the way for measurement and test instruments. Let's start with the basics and work up from there.....
    To make it easier to read and tabulate at a glance please cut and paste the block of options below and modify my own "yes" and "no" to suit your own collection. And then add any comments after that please.
    Sliding calipers (vernier, dial, digital)- yes
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Sensitive (.0001"/.001mm) test indicator- no
    Telescoping gauges- yes
    Small hole gauges- yes
    Bore micrometer- no
    Granite or iron surface plate/table - yes 12x18 in
    Sliding height gauge- no
    Height tester - yes (shop made)
    Precision test centers - yes (shopmade)
    Reference square - yes (shop made)
    Gauge block set - no
    Gauge pin set- no
    Sine table or bar- no
    List any other advanced measurement gear you have which isn't covered.
    ___________________________________
    Tabulated results- Total respondents- _32__ as of 11:40 PDT 24-08-19
    Sliding calipers (vernier, dial, digital)-_32__
    Micrometers- _30__
    Dial gauges- _29__
    Test indicator- _28__
    Sensitive (.0001"/.001mm) test indicator- _22__
    Telescoping gauges- 28___
    Small hole gauges- _22__
    Bore micrometer- _22__
    Granite or iron surface plate/table - 29
    Sliding height gauge- _27__
    Height tester - _16__
    Precision test centers - _9__
    Reference square - _17__
    Gauge block set - _22__
    Gauge pin set- _9__
    Sine table or bar- _16__
    Other items in no particular order-
    Various sensitive or heavy item scales-6
    laser temp sensor-3
    fancy shmancy stabilized laser and nothing else
    Good Depth gauges - HOW DID I FORGET ABOUT THOSE ! ? -2
    Thread wire sets (another faux pas on my part) - 4
    And the coupe de grace.... a tool room microscope...... <drool>-5
    USB or older optical microscopes. This sort of fits in with the tool room microscope but perhaps not quite on the same level.-3
    Machinist's levels. Another DOH! moment for me. So far - 9
    Depth micrometers- 7
    Optical comparators - 3
    Radius gauges-6
    Balancing stand
    Surface finish comparator or comparison set- 3
    A couple of you are confused by my height tester. I may have the wrong name but it's a base with a column that you can attach a DTI onto and test the height of items. Some might just use a magnetic base or others may be using a sliding height gauge with a mount for their DTI. The really nice ones can also angle the finger for the DTI down or up to nearly vertical and with the bumper on the base use them as squareness comparators. I hope that clears up THAT entry.
    The fancy stuff lower on the list seems to be rising up in the percentages. Over half of the present list of responders have gauge block sets. And just under half have sine tables or bars.
    Atascosa County, Texas
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Sensitive (.0001"/.001mm) test indicator- yes
    Bore micrometer- yes
    Sliding height gauge- yes
    Height tester - yes
    Precision test centers - no
    Gauge block set - yes
    Gauge pin set- no
    Weight scale, 1/100grm digital - yes
    Weight scale, 1000lb digital - yes
    Laser temp sensor - yes (For expansion factors)
    Digital angle/square - yes
    And old fashioned rulers and tapes.
    Mar 2015
    My list of metrology items is severely lacking. I started to acquire Mitutoyo outside mic's, and buy as I need something. No sine bars, no gauge blocks or pins. Do have a surface plate and height gauge. A couple of crappy HF calipers, and a set of tiny telescoping gauges that I suspect are fake Mitutoyo from Amazon as they feel Chinese with a Chinese or Indian finish.
    Aug 2012
    Warwickshire, UK
    Gear tooth vernier callipers, imperial and metric.
    Not used often, but useful when they are needed.
    May 2018
    SE MI USA
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Bore micrometer- no
    Granite or iron surface plate/table - no
    Height tester - no
    Gauge pin set- no
    Jun 2016
    Iodine-Stabilized HeNe Laser
    Aug 2018
    Northern WI
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Small hole gauges- no
    Bore micrometer- no
    Granite or iron surface plate/table - yes 9x12
    Height tester - no
    Reference square - no
    Gauge pin set- no
    List any other advanced measurement gear you have which isn't covered:
    - Adjustable parallel set
    - Vernier depth gauge
    - Dial bore gauge
    - 1-2-3 blocks
    - 4X and 10X loupes (not sure if they count?)
    Woodinville, WA
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Granite or iron surface plate/table - yes 24x24, 18x24, 10x10
    Height tester - yes
    Gauge pin set- yes - 30(?) thou to 3/4 in 1 thou steps
    Sine table or bar- yes
    Rusted Stanley tape measure, many, bent ends.
    Thanks, that's a great start. I'll give it a couple of more hours then do the first tabulation update.
    Aug 2004
    York, PA
    Micrometers- yes
    Dial gauges- yes
    Test indicator- yes
    Granite or iron surface plate/table - yes 12x18, 18x24 in
    Height tester - no
    Gauge pin set- yes
    Dial bore gauges
    Scale 200 g/.001 g
    Scale 5500 g/.1 g
    Scale 150 kg/10g
    Crane scale 1000 kg/.5 kg
    Toolroom microscope .0001"/.0001"
