Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Making small bolts
    Sep 2006
    Southwestern Ontario, Canada
    Default Making small bolts
    I have to make a lot of small bolts, #6 & 8 for sure but a lot of smaller ones right down to #1, lots of 2's, 4's and 5's. My problem is that threading dies don't thread up to the base of the head even if it is reversed and run on the thread a second time. Yes a recess can be turned by the head but a lot of times I need the thread to actually be full length.
    Is there a better way to get a full length thread????
    Oct 2006
    Ivins, Ut
    Seems if you're making a 'lot' of these, thread rolling might be the way to go.
    Here's an old thread with some interesting info: http://bbs.homeshopmachinist.net/arc...hp/t-8465.html
    Strongsville, Ohio
    There's no good way of doing it. I use dies for all my small threads and some are better than others for getting up against the shoulder. For small stuff it doesn't take many threads to hold good so in a lot of cases I don't worry about getting up against the shoulder I just counterbore the threaded hole a couple of threads so the unthreaded portion of the screw goes in.
    gbritnell
    Atascosa County, Texas
    I've always just turned the die around. If that's not enough, chamfer the hole it goes in or chamfer more. That's what it's for.
    Feb 2004
    You could grind or mill off the back surface of the die so the threads go all the way.
    Jan 2014
    In the desert
    Quote Originally Posted by portlandRon View Post
    I had that same thought. Might have to make a spacer or washer so it sits flat in the die holder after you grind it when threading with the front.
    Jan 2014
    Long Island, N.Y.
    If hex head bolts are OK, use lengths of threaded rod and tack weld (or loctite) nuts onto the ends.
    There's a reason why both sides of a die are chamfered. If you grind it back like that you will create a sharp edge on the die's thread and that will not last long if you are threading anything harder than soft clay.
    A design that requires a thread right up to a shoulder is not a good design.
    If you really need a thread right up to a shoulder, use threaded rod and solder, braze, or glue a nut on it for the head.
    Helsinki, Finland, Europe
    Making large number of screws with dies sounds madness, is there something special about these that store-bought screws don't suit?
    Thread milling or thread whirling would get you close to head but... actually I want to see someone enough crazy to DIY thread whirling machine
    Mar 2015
    You build scale models, and want scale hex head bolts. Otherwise, McMaster does sell bolts that are full threaded for a bit more money. Smaller size hex stock is much harder to find these days, why people start asking about such things.
