Results 1 to 10 of 37
Thread: 400,000 revolutions per minute air grinder first use
    Feb 2011
    Default 400,000 revolutions per minute air grinder first use
    I ordered this dental grinder $25. Plus and assortment of bits are about $.60 each. More are on the way. The gear selector switch on my Polaris was full of water. I pierced two small holes in the lower portion. I blew air and contact cleaner and WD 40 into it. It works fine. I only have one style of carbide bits however I have five types of diamond burs . Here are some pictures of what it does.Edwin Dirnbeck
    Feb 2014
    That picture of the tap is interesting. Where did you order the grinder from?
    Jul 2015
    S.E. MI, Metro Detroit
    Nice work Edwin, you must have a steady hand as well.
    Buffalo NY
    Home Shop Dentistry. Perfect.
    --Doozer
    DZER
    Jan 2013
    Michigan
    Edwin! Can you make and fit a crown?
    Feb 2011
    Quote Originally Posted by Yondering View Post
    Got it from Amazon
    WOW, 400k R's. I wonder what it has for bearings?
    JL.....
    Jan 2002
    Huntsville Ala
    I'd think it'd spin in air bearings.
    (I assume it's being propelled by air.)
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by Edwin Dirnbeck View Post
    Got it from Amazon
    I want one. I have some of those inexpensive drills with the colored collars. Will it work with those? I think 1/8" dia. JR
    Nov 2011
    Salem, Oregon
    It's hard to tell from his photo, but if a 10-32 tap is 0.19", that shank appears to be less than 1/8".
    Dan
    “All political power comes from the barrel of a gun. The communist party must command all the guns, that way, no guns can ever be used to command the party.” (Problems of War and Strategy, Nov 6 1938, published in “Selected Works of Mao Zedong,” 1965)
