Results 1 to 10 of 10
Thread: Is it common for a lathe bed to be very hard to remove off its cabinet?
    Aug 2008
    Toowoomba, Qld
    Default Is it common for a lathe bed to be very hard to remove off its cabinet?
    I have stripped down my lathe and have unbolted it from the cabinet. She is stuck down real good.
    Would they have used a glue or some type of resin under the feet of the lathe bed to help "bed" it into the cabinet surface?
    Boxford MK1 VSL
    Mar 2015
    Quote Originally Posted by apples View Post
    Boxford MK1 VSL
    Maybe, if flood coolant was used or expected to be used, some people may run a sealant around the feet to keep coolant from getting to the cast iron.
    May 2005
    Australia (Nth. Brisbane)
    If coolant is used then sealant will be used to stopl it leaking into cabinets through bolt holes.
    Nev.
    Aug 2012
    Warwickshire, UK
    Tony Griffiths (www.lathes.co.uk) specifically advises against separating a Boxford bed from the cabinet stand because a sealant was used to prevent coolant leaking under the bed feet and into the cabinet. He says it sets hard and if you separate the two you will have to remove all the hardened sealant and then re-seal when you put it back together.
    What did your bearings look like when you got them out?
    Aug 2008
    Toowoomba, Qld
    Richard, I have not washed them off as yet. On first inspections they look okay, so fingers crossed they will be.
    Aug 2012
    Warwickshire, UK
    For what its worth, when I was renovating my Raglan lathe (similar size to yours) the Raglan handbook recommended washing the bearings out with white spirit, I did this in an old glass bowl, so any dirt fragments could be seen easily. I think I had to wash them 6 times before the white spirit stayed clean and there were no bits in the bottom of the bowl.
    Is there a rubber gasket between the cabinet and machine?? I've seen a few lathes with them, like my Clausing for example. The rubber gasket can soften / rot and become soft and sticky over the years really stick to both parts.
    JL.........
    Apr 2012
    NE Thailand
    Quote Originally Posted by Richard P Wilson View Post
    This.
    Worth a full read for newbie Boxford owners.
    Yes, and the factory likely had everything accurately leveled as the sealing agent cured. Might be something an amateur could not easily duplicate.
    May 2015
    Somerset UK
    I understand the need to seal the joints, but wouldn't this make levelling, (aligning the bed) impossible?
    As for cleaning the bearings, I had to remove and clean a pair of needle roller bearings, and like Richard, I had to wash them repeatedly in clean solvent until no more old dirty grease particles came out.
