Results 1 to 10 of 13
Thread: How do I seperate the lathe bed from the cabinet?
    Aug 2008
    Toowoomba, Qld
    Default How do I seperate the lathe bed from the cabinet?
    I have stripped all the parts off the old girl. Now I really would like to split the lathe bed from the cabinet.
    Also it looks like it has a joint on the leg risers. But there are no bolts holding it together that i can see.
    I know its been glued or cemented or something. Man its stuck good.
    Aug 2008
    Toowoomba, Qld
    Aug 2008
    Toowoomba, Qld
    Dec 2002
    Friesland, Netherlands
    It's the joint on the risers that you're trying to split? Maybe too obvious, but if you unbolt the risers from the cabinet and turn the whole lot upside down, might there be bolts inside the riser?
    Ian
    All of the gear, no idea...
    Aug 2012
    Warwickshire, UK
    Tony Griffiths warns against splitting a Boxford bed from its cabinet because when originally assembled the factory used a sealant to prevent coolant from leaking into the cabinet. With time this sets really hard and is difficult to get apart, but if you do, then you've got to get the remains of a rock like sealant off, and re-seal on assembly.
    Those risers look like they are bolted on from underneath.
    May 2005
    Australia (Nth. Brisbane)
    Quote Originally Posted by Ian B View Post
    .......... might there be bolts inside the riser?
    I'd say you got it.
    Nev.
    Aug 2008
    Toowoomba, Qld
    Yeah fellas, obviously I have the four bolts undone. I just popped them back in as I was going to lift up the lathe bed with a strap under the lathe bed. But I did not need to do it because I was able to just push and drag the cabinet around.
    Yes Richard, you mentioned this to me once before. I am a welder/fabricator and I have had to grind through some nasty stuff in the past, I am sure this won't stop me.
    I'll have to take another photo so you can see the inside of the top down view of the lathe bed.
    So far I have just been reefing down on a length of timber to try to pop it off the cabinet. I might need to put a jack underneath the bed and the cabinet.......????
    Aug 2008
    Toowoomba, Qld
    Aug 2012
    Warwickshire, UK
    If its proving so difficult, do you really really need to separate them?
    Aug 2008
    Toowoomba, Qld
    Well yeah it's a bit like that. It will be so much easier to properly wash and paint if can separate it thought.
