Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Least used machines
    OREGON
    Default Least used machines
    I didn't want to hijack the most used tools thread, so here we go: This is about the machine that you use the least. I have lots of tools that haven't been used for many years, and some that will never be used again. A prime example would be a few purpose built wrenches I inherited from my wife's grandpa. Heirlooms. But not what this thread is about.
    In the early 2000's I had the hots for a small shaper. I got a 7" Atlas, and fixed it up. I used it some, until I got a Bridgeport. Alot less after that. Then I got a Sheldon horizontal mill, And used the shaper even less. It's pretty, and not in my way so it will stay in the shop.
    So what do all do use the least? and, why?
    Nov 2008
    SF East Bay.
    I have a 20 ton press with air over oil jack for the ram.
    It's been in the box for 5 or 6 years now. After I got it home I realized that I don't really have a place to park it when not in use.
    Dan
    Nov 2013
    SF Bay Area
    I have a very nice Mitutoyo dial bore gauge that I got for precision fitting two-stroke pistons. Necessary if you really want to achieve the ideal .0015" bore-piston clearance.
    I don't do engine rebuilds any more, haven't used it for ten years or more. Probably should sell it.
    -js
    Jan 2014
    In the desert
    Least used tool in the shop is probably the 2HP Delta 230V radial arm saw. I'd get rid of it tomorrow if somebody made a half way serious offer.
    I grew up using a radial arm saw. My dad still has it. On my own I wound up using a table saw (contractor saw, not serious cabinet saw) and a miter saw. Now a compound radial miter saw. By the time I could afford a real big boy radial arm saw I had gotten so used to doing anything I needed done with my other saws that the RAS has mostly sat idle. I mean any serious wood working project I walk over to the house where my wood shop is and use the table saw or the miter saw. I even moved my smaller vertical bandsaw over to the garage shop on the house recently after making a new table insert and installing a brand new Wood Slicer resaw blade. The RAS is just wasting valuable real estate in the shop. It needs to go.
    I have junk parts on the shelf I'll likely use before I ever use the RAS again. I actually unplugged it and rolled it out by one of the front overhead doors to make room for my new variable speed metal cutting vertical bandsaw.
    Mar 2015
    Both mills, and lathes. But that has to do with nothing getting done in the shop
    I'll elect the lowly shaper, not for me but for others who own one, most all iv seen in others shops are covered with about 1/16" of dust,,,
    I will never own one - I could live a thousand lifetimes and never even need one - there is not a single thing a shaper can do for me - I despise the fact that so much cast iron had to be mined from our precious earth - refined and molded into such a despicable "shape"
    in this world there are boats of every size and these boats all require a specified weight to anchor them to the sea floor, im sure certain shapers fall into that perfect weight zone, I would just love to see some vessel with a chain hanging off the front and a barnacled shaper attached to it - now that would be a picture worth framing....
    I hate shapers...
    Sep 2008
    New Zealand
    The dove-tailing attachment for the router.
    Used it once to make a bread-box about twenty years ago and haven't used it since. Life's too short for dove-tails (and now I live in the sub-tropical north, I have to keep the bread in the fridge anyway!).
    Aug 2004
    Sunny So Cal
    I built a 50 ton press 25 years ago to build a car and haven't used it in 18 years or so. JR
    May 2015
    I had a nice Delta/Rockwell ten inch radial arm saw that I used extensively until I got my ten inch Unisaw. I could not find anyone interested in the radial arm saw, and ended up practically giving it away to a local pawn shop. I have a seldom used Delta six inch joiner-planer that is very nice. I need the space but I cannot find anyone interested. It seems that the younger people are not doing much woodworking these days.
    Oct 2008
    Canton, Ga
    Shaper for me too. Got a really nice South Bend 7" on cabinet in trade for machine and welding work. One thing I have done is cut a
    keyway in a large bore gear. Perfect job for a shaper. Beyond that never had a pressing need to use it. I just had to have one though!
    RichD. It's available.
