Results 1 to 10 of 13
Thread: Feed and Speed for Garolite LE?
    Montvale, NJ
    Default UPDATED: Feed and Speed for Garolite LE?
    I have to mill some insulators from 1/4" thick stock. I can find info on other grades, but not this "easy to machine" grade. Supposedly you can just use HSS to machine it because it uses cloth instead of fiberglass as the reinforcement.
    Anyone ever mill this stuff before?
    Thank you.
    Jul 2017
    Buffalo NY USA
    Quote Originally Posted by polaraligned View Post
    Thank you.
    Never milled plastics, but it sounds like its related to Micarta in the way it uses cloth. Is it a proprietary type? Some quick googling shows this: https://www.wshampshire.com/ryertex/
    which bears out my theory that its just a trade name for Micarta. Should machine like hardwood, but I've never actually done it.
    Jul 2017
    Springfield Mo
    McMaster says its just a trade name for phenolic. Havent machine phenolic, but i have gone through micarta, which is near enough to be the same thing. Honestly, you can rip through it pretty easy. Id say same general speeds as if you were cutting something like acrylic. Sharp tools, mid-high rpm, decent feed to keep it from just melting/burning on the tool
    Montvale, NJ
    Thanks. Searching for Micarta got me to a thread on PM that discusses milling the cloth based phenolic, which is what the LE is.
    I think I will put in the 20K RPM sub spindle and an 1/8" carbide endmill and see what happens. Melting on the endmill would be bad.
    Will be running this CNC.
    This is the part, the holes are 0.2" for scale.
    Montvale, NJ
    Just ran Gwizard for 1/8" carbide at 20K RPM. Looks like feeds need to be in the 50 to 100 ipm range for hard plastics.
    Saskatoon, Saskatchewan
    Like many things, don't forget to account for the hazards of the dust that might come from machining it. It might be quite abrasive and breathing it is likely to fall in the category of "bad things to do".
    Thank you.
    Yes, I've milled both the cloth and the glass. Cut both on my table saw with a carbide tipped blade.
    JL................
    Feb 2003
    NorCal
    It machines “like butter” for the most part. Unlike real butter, it is far stronger, you can tap it and make reasonably strong threads, and it won’t melt. The exit sides of drilled holes can chip if you push too fast and hard on breakthrough. The burrs consist mostly of fiber fuzz. I use a shop-vac to control the dust. It can be smelly if you get it hot. It is not particularly abrasive, unlike the G-10 fiberglass grade.
    Sep 2018
    It's not "eat your face" dust like fiberglass. The worst aspect is it reeks. Really doesn't melt either; it's not a thermoplastic.
    Oct 2012
    San Antonio TX, USA
    Quote Originally Posted by rklopp View Post
    yabbut, can you spread it on your toast?
    Polaraligned, what's it going to be insulating? Looks almost like something to hold a heating element.
