Results 1 to 10 of 15
Thread: What are these used for ?
    Sep 2007
    West Chester PA
    Default What are these used for ?
    Sep 2013
    Quote Originally Posted by KiloBravo View Post
    Arbors for between center work
    You don't want them, very dangerous things. Send them to me , I will take care of them.
    (Very good care ;-)
    Oct 2009
    South Florida
    Those are mandrils, they are slightly tapered cylinders used for holding things like gear blanks or other circular pieces with a center hole between centers on a lathe. Idea is you press the workpiece on the taper (usually only 1 or 2 thousands) until it's firm and then turn your work. (sigh) I bought a complete set years ago when I set up my shop and have never had a workpiece with a hole that was exactly the right size to use them....
    Atascosa County, Texas
    Actually, they're mandrels. The other is a monkey.
    May 2015
    Coral Springs, FL
    There should be numbers stamped on the ends, like 0.4995 and 1.0005 on each mandrel.
    Oct 2013
    USA MD 21030
    Images have disappeared. Hosted by "Google User Content".
    Aug 2016
    Appalachian Ohio
    He took them to use them.
    Oct 2009
    South Florida
    Point taken, thank you!
    Oct 2013
    USA MD 21030
    They aren't mandrels - they must be called persondrels...
    Germany
    Excuse me but those are absolutely Unidrels not MANdrels or Persondrels.
