Results 1 to 10 of 19
Thread: Quick and dirty tracer lathe
    May 2011
    N.E. Arizona
    Default Quick and dirty tracer lathe
    Hi Everyone,
    Years ago I had to run a job that had a 14 inch long taper from 3/8 to 5/8 diameter. Problem was I had no taper attachment.
    Having worked in a toolroom where we had several lathes with hydraulic tracer attachments I realized I might be able to do the same thing without the hydraulics.
    I made two risers to hold a piece of flat bar at the angle I needed:
    Then with a dial indicator fastened to the crosslide I could run the machine and manually keep the needle on zero with the power feed advancing the carriage:
    I also made a follower rest and made the cut all in one pass:
    These photos are only to show how I did it. The actual parts were around twenty inches long.
    More in next post..........................................
    I've been wanting to try using the same idea to duplicate a complex shape and this Last year I made a couple of ball cranks for a friend's Elgin mill.
    Best wishes to ya’ll.
    Sincerely,
    Jim
    May 2011
    N.E. Arizona
    This shows the high tech coolant system:
    This is right after turning without any filing or other finishing:
    For the longest time I have been itching to try this with a more complex shape, such as the compound curve of a ball crank handle. Last year I got the chance.
    Here is what I came up with and it worked way beyond what I thought it would:
    I used a more sensitive indicator and a slower spindle speed than I had done with the long taper. Another view:
    Finished parts in the next post.............................
    Sincerely,
    Jim
    May 2011
    N.E. Arizona
    All it took on the compound curves was a small amount of emery cloth while still in the lathe and the final finish came up easily with a buffer:
    The three balls and taper shaft were done in another lathe with a ball turning attachment.
    Sincerely,
    Jim
    May 2011
    N.E. Arizona
    One more thing I just remembered, these risers can be used in the front as shown or on the rear of the bed where the template is more out of the way.
    Sincerely,
    Jim
    Mar 2008
    Kent, U.K.
    That's great ingenuity but I don't know how you managed to use a follower rest on a tapered part. The rest would follow a parallel path whilst the part gets larger in diameter.
    Monarch 10EE 1942
    Jan 2016
    looks like the follower rest is bolted to the side of the carriage, not to the cross slide.
    Dec 2008
    Kendal, On
    Quote Originally Posted by Peter. View Post
    You'd use tapered roller bearings....
    Mar 2008
    Kent, U.K.
    Quote Originally Posted by johansen View Post
    Which is usual, and I just re-read the post that it was cut in one pass which explains the use of the follower. If there were multiple passes it obviously wouldn't work.
    Monarch 10EE 1942
    Jan 2017
    Quote Originally Posted by jhe.1973 View Post
    Is it me or is there a corner about a 1/4 of the way from the right? Maybe that "... manually keep[ing] the needle on zero ..." is not as easy as it sounds?
    Here is a solution I came up with for turning long tapered and contoured parts...
    http://bbs.homeshopmachinist.net/thr...r-Manual-Lathe
    http://bbs.homeshopmachinist.net/thr...13#post1211213
