Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 139
Thread: OT: Sad day in aviation: Collings B17 has crashed
  1. #111
    Cockpit picture. Presumably the 4 large levers are throttle, and the smaller ones forward of that are the mixture controls.
    https://shootaviation.com/sets-and-m...1079-gallery-2
    Dec 2018
    Funny you to mention the 'cowboy' attitude.
    I've seen cowboy pilots get lightning strikes, turbulence inspections, hard landings inspections, et. al.,
    BUT, I've not seen a cowboy pilot 'crash & burn' in a heap.
    Just sayin'........30years A&P
  3. #113
    Mar 2015
    You've never seen the B52 crash at the airshow? The Florida Jet 737-200 crash into the icy waters on takeoff, or countless other crashes where CRM wasn't followed due to cowboy attitudes?
  4. #114
    Oct 2013
    USA MD 21030
    On August 31, 1988, I was flying into DFW, and we could see smoke and wreckage on the ground as we were landing. After landing, we learned that a plane had crashed on take-off, and it was determined that the crew had been joking around and had neglected to properly configure the aircraft for take-off. Also a critical alarm was non functional, not checked by maintenance.
    https://en.wikipedia.org/wiki/Delta_...es_Flight_1141
    https://www.dallasnews.com/photos/20...port-kills-14/
  5. #115
    Jun 2007
    Anderson SC
    I remember a turboprop crash years ago where the final report showed the pilot intentionally put the engines into beta/ reverse thrust position before touchdown. Apparently not the first time either.
    https://apnews.com/11e40928395518d4ebb7b34dd67ea209
  6. #116
    Mar 2015
    There are two points in aviation history where fatalities had a significant drop. The wide scale adoption of gas turbine engines, and the second, adoption of Crew Resource Management.
  7. #117
    Jun 2007
    Anderson SC
    I am sure that is very true, my point was the existence of a few cowboys out there.
  8. #118
    Mar 2015
    CRM removed the cowboys from the cockpit at 121 airlines
  9. #119
    I think there are still a few oddities around. That Canadian deal where the crew landed at the wrong place, and some "removed for being drunk" etc. They end up removing themselves, but hopefully just themselves.
    What were the means by which CRM has removed "cowboys" , and hopefully also "idiots"?
    Mar 2013
    Hightstown, NJ
    I just looked the NTSB site video for the first time. That Quonset hut was actually a tent and the metal building to the left was put up while I was working there to house vacuum evaporators that concentrated up the Glycol to about 50% from the 10% or so that we produced in the tent. You can see the equipment I installed through the big hole. In the center is an ultrafiltration unit and behind it you can see the large white tubes of the 2 stage RO unit. Glad I was NOT there for this!
