Results 1 to 10 of 20
Thread: Irregular work piece vise
    Default Irregular work piece vise
    A few years ago I saw a vise in a catalog or ecommerce site with partial semicircular inserts for holding tapered or other irregular work pieces. One jaw had a single sliding semicircular insert and the other had two semicircular inserts, kind of like "[(| B]" . (I'm new to the forum and can't insert a drawing yet.) I recently had a use for one but was unable to recall or locate the original source. If anyone recognizes this, any help would be appreciated. Thanks.
    Sep 2015
    NW Illinois
    I know exactly the vise you are referring to. Unfortunately I can't remember the vendor's name. I do recall it is very spendy.
    Seems you could easily roll your own. Make a vise jaw with some large (1"?) holes in it with a generous chamfer. Then get some 1.5" ball bearings and cut them in half. Put magnets inside those holes in the vise jaw to hold the hemispheres in place.
    Jan 2014
    In the desert
    Not knowing the nature of your work piece I can't say this would fit your needs, but aluminum soft jaws machined to fit the part are one of the most used nonstandard vise holding methods in a production shop.
    Jan 2013
    Michigan
    Mcgyver posted an awesome quick change jaw setup less than a year ago. It's on my list..
    http://bbs.homeshopmachinist.net/thr...72#post1210372
    Saskatoon, Saskatchewan
    Quote Originally Posted by RBKirkpatrick View Post
    Welcome to HSM!
    Would this little accessory be useful?
    https://www.garrettwade.com/gyrojaw-...essory-gp.html
    Feb 2009
    St Paul, Minnesota, USA
    Albuquerque
    Here is another method to hold a tapered in one axis if it helps .
    ... Lew...
    Holding oddball shapes have a wide variation in what works and what doesn't. Paul's advice about a sub jaw with a hole, or even a good chamfered depression and a half ball as a floating jaw is a great idea. For other things you might consider making a shallow "V" sub jaw so a lump shaped object is at least held by three spots instead of just two and just go easy with light cuts.
    Another option is to "pot" the lump or odd shape with something that will harden but which can be broken away easily enough later on. It might be some epoxy or might be cast lead or even something like floor tile cement (which is pretty tough and durable after curing for a couple of days). This might give you enough of a saddle to support the odd looking item to allow machining details then break it away and clean up after.
    Oct 2013
    I think you're referring to a Morton multi-vise. I bought one at auction last month, they're very nice little vises that come in handy once in a blue moon.
    Lee
    Sent from my SM-N960U using Tapatalk
Tags for this Thread
