Here is some pics of a in place machining repair I just did in San Francisco. Thought someone might like how something like this is set up and done.
This was the drive end before I started.And they wondered why they couldn’t keep oil in the bearing!!!!
After 8 hours of welding and a spool and a half of .045 wire. This is what it looked like.
Finally set up and turning.
This was the other end. Damage wasn’t as bad as drive end. Bearing was spun. Nothing to mount lathe to so we had an adapter plate made up, then we drilled and tapped the end to bolt it up to.
3 days(39 hours) later and this was the final cut . This pic was taken off a cat walk of another piece of equipment. Center line of shaft was 10 ft. off floor.After we got it back together it was off to the Wharf for a few Anchor Steam's!!!!!
[This message has been edited by burnlast (edited 12-15-2004).]
