Jim try to reply to your original thread rather than make new posts, it's easier that way.
I don't have a diagram of my pinout handy but I'll look around tommorrow. Make sure you have the machine in setup mode, flip the reset switch inside the tape reader cabinet, then press edit. The machine should relay back to HyperTerminal
BOSS 5.0
>INPUT
After that you can "send text from file" press CTRL-Z after the code has been sent.
-Christian D. Sokolowski
True happiness is not having what you want but wanting what you have.
