fig.01-A homebuilt transfer punch for holes up to 1-1/4 inch.
-- clockwise-left to right--
* 1-1/4 in shaft 1-3/4 inches long with a taper turned on one end and a 1/4 in hole bored thru using a lathe.
* 1 1/4 inch I.D. tubing 1 inch long faced square on both ends.
* 1/4 inch transfer punch.
fig. 02 - Tapered end of center piece set in hole to be transfered to workpiece.
fig. 03 - The outside tubing placed over the inside tapered part to line up the center part (to keep it straight up and down instead of cocked in the hole) and a 1/4 inch transfer punch inserted in the center hole to center punch the center of the hole for drilling.
I get lots of odd sized holes and this tool kind of eliminates making special sized sleeves and is simple to make and accurate.
irnsrgn
[This message has been edited by irnsrgn (edited 01-19-2005).]
