3/4 shank with a recess (trepan) in the bottom so they can register up against the spindle nose. I need one more preloaded and measured for 6-32. Those 3 are all pre measured for the Tormach 1100 and entered in the tool table. I run them with a drill routine, with some extra parameters set. so far I haven't seen more than 1.5-2 threads over or under run at 500 RPM. I've got all my preset styles for these set at 500 RPM. When I need to tap a hole I just pull up the style I have preconfigured in CamBam and set the depth.
Now I need to figure out how to make some in KWIK-200 shank.
