Bits & Pieces
  • Bits & Pieces
    I've changed my method of machining a little bit were often I simply cut out by slotting a piece because it's faster than machining away all of the material. The amount of time it takes is more important to me than whether or not I wear out an end mill. as a result I've started to get small accumulation of bits and pieces like these. I was wondering if one of you guys could use them. Not somebody who just wants to take something cuz it's free but somebody who actually actively does machining using small pieces of stock like this.
    Az, USA
    If it's more trouble than it's worth I'll just keep tossing I'm in a bucket.
    Click image for larger version  Name:	KIMG1240.JPG Views:	0 Size:	1.89 MB ID:	1884799
    That's very generous of you Bob. I have all I need, but I bet there are plenty of newbies who would love some of those.
    Dan
      My hope was that somebody who barely scraped together enough money for a used Taig might see my offer, but really anybody who would actually have a use for such small bits and pieces would be ok.
        Ill always jump at the opportunity to get my hands on some bits and pieces, seems like i always need a small piece of something i just dont have. Mind if i PM you?
          Go ahead.
            This is a great offer.
              I call those Melty Bits, because I am doing lost foam castings for fun. I found that the 6000 series alloys cast pretty well if you add about 7% silicon. That makes the alloy quite close to 356 casting alloy in content.
