Originally posted by RB211
View Post
Haas VF-OE: can I use Argon instead of Nitrogen for the counterbalance?
- Likes 1
I think nitrogen has less slip stick! π lol. Itβs fine, just more$
Haas will just try to sell you the whole contained system. Running an F1 team is expensive.
I just went through this at work with our VF3. I got a charging kit from McMaster, and got a bottle of nitrogen dropped off from our welding gas supplier. Back in business.
I installed a Mini-Split A/C system in my shop
and I wanted to purge the lines and do a pressure
check overnight. I did not have nitrogen, but I had
argon at a few hundred psi. I filled my lineset with
350 psi argon, checked for no pressure drop the
next day, then I pulled my vacuum.
I also did a "dry-break" on the vacuum a few times
using argon to catch every last bit of moisture.
Been working fine for over 6 years now.
I did a few pressure check on A/C systems with
argon over the years, because it is what I had for
my TiG welder. I would for sure charge a shock
absorber with it in a heartbeat.
----Doozer
FWIW since it is a little late now, argon will be just fine, if there are any leaks it will just leak a little slower.
Update:
I have posted a full overhaul thread here with a complete list of components:
"Overhauling counterbalance and rebuild thread: full parts list and procedures"
https://www.practicalmachinist.com/v...0-post3739785/
The kinetic diameter of argon and N2 is almost the same. As is the molecular weight.
its isnt going to leak any faster.
- Likes 1
Originally posted by garyhlucas View PostTwo reasons, first is cost with nitrogen being dirt cheap. The second is that I believe Argon is much more difficult to seal so it likely will leak out fairly quickly. However definitely no harm done.
No?
HTML Code:(My Notes) "High-Pressure Inflating Connection Schrader 1/8 In NPT Male, Manufactured by:Amflo, Toolsource #:106074, Manufacturers Part #:556, Also Known As:AM556" https://www.toolsource.com/air-couplers-and-fittings-c-1421_372/highpressure-inflating-connection-schrader-18-in-npt-male-p-106074.html Toolsource is an idiot company that sent me the wrong thing. Trying www.PegasusAutoRacing.com. "JGB Enterprises-A171-1004-0048 JGB-JFlex Hydraulic Hose, 1/4"x4', Male NPT x Male NPT Connection, 1-Wire, 3265 psi, Black" https://www.amazon.com/JGB-JFlex-Hydraulic-Hose-Connection-1-Wire/dp/B0107O99DC "Legines NPT Reducing Coupling Brass 1/4" Female x 1/8" Female, Hex Reducer Coupler Adapter Pipe Fitting 1200psi (Pack of 2)" https://www.amazon.com/gp/product/B07486QJKK "2 Pack 1/4" x 1/4" NPT Coupler, Brass Female Pipe Fitting" https://www.amazon.com/gp/product/B082V8FJQJ Choice of these two: "UNIWELD, Nitrogen, Specialty Gas Regulator, CGA-580, Single Stage, Brass, 50 to 800 psi, Item # 39DM34, Mfr. Model # RHP800, UNSPSC # 40142201, Catalog Page # 2428" https://www.grainger.com/product/UNIWELD-Nitrogen-39DM34 "Harris Single-Stage 25GX Argon/Nitrogen/Helium Regulator β 500C PSIG, 580 CGA Fitting, Model# 3000606" https://www.northerntool.com/shop/tools/product_200715962_200715962
Originally posted by Sparky_NY View PostOne of the ....
Nitrogen is used only because it is cheaper, but Argon is perfectly fine.
100%-Argon for welding would have no impurities of course.
Still, there is no one I can find that says, "Yes, I used Argon for ten years and everything is good."
I have decided I am using Argon.
If anyone has doubts about the long term prognosis, then please comment below. It's easy enough for me to purge and replace.
One of the reasons "dry" nitrogen is so popular for a variety of uses is that it is one of the cheapest gasses available as well as being inert. Argon is considerably more expensive. I have no idea if bottled argon's moisture content is as low as "dry nitrogen", something to consider. I would think you could sub argon without issue, but that's only a guess.
