Resolvers.. Still a viable with current technology..
  • Resolvers.. Still a viable with current technology..
    Working on getting a 70's vintage nc lathe running I have also been playing with resolvers. Granted there are comercial solutions that work better (pico and mesa)
    part 2
      Resolvers I have are from aviation and designed for 400hz AC.
        These are rated at 400hz also. They seem to work good at 2khz.
          But you must feed them that signal. There exists resolver motors and others. So apparently you can drive something 1:1 electrically.
            Analog Devices makes resolver to digital ICs. Not too expensive and handles excitation and A to D. They even have simulated quadrature encoder outputs: https://www.analog.com/en/products/ad2s1210.html
              Resolvers were used in early CNC M/C's but as mentioned they have inertia and also require excitation etc.
              The modern replacement is the quadrature encoder used with the direct photo-LED sine wave output before it is squared up as in the typical quadrature versions.
              The co-tangent calculation is the same result as the resolvers were.
              .I recall the first optical quadrature encoders/scales that had an incandescent lamp for use in the read head, every time you replaced the bulb, the resulting sine wave phasing had to be done with a scope using a Lissajous figure to set the 90deg offset. !!
