I have a brand new one... in a box somewhere.
Cheap and dirty lathe conversion.. (Old Nebel lathe)
Putting the ball screw in the cross slide (x axis) we are mounting the stepper on the back side of the lathe. So - we needed to put a hole in the back side of the saddle for the ball screw to pass though. Found an old shaft (threaded on one end - no clue what it was from)
turned down the end so it would pass through the existing brass nut and used it to drill and bore the back side of the saddle...
When mounting the ballscrew, at least the ones I have, the threaded section of course takes a nut, but there is no register against the ball threads. So what is the proper method to remove lash? Angular contact bearings preloaded with a nut on the threaded side, what about the other side?
RB - do you have a picture? I am not understanding what you mean. Mine had a machine section between the ball screw and the threaded section. I made a bearing block that has a section that keeps angular contact bearings apart. The nut pre-loads the bearings. (going to use jam nuts.) the opposite end - we just have a bearing to keep it from flopping around..
Sorry - forgot to quote you ^
Originally posted by skunkworks View PostRB - do you have a picture? I am not understanding what you mean. Mine had a machine section between the ball screw and the threaded section. I made a bearing block that has a section that keeps angular contact bearings apart. The nut pre-loads the bearings. (going to use jam nuts.) the opposite end - we just have a bearing to keep it from flopping around..
